-   -   chtMultiRegionSimpleFoam Problem with liquids since 2.0 (http://www.cfd-online.com/Forums/openfoam-solving/91064-chtmultiregionsimplefoam-problem-liquids-since-2-0-a.html)
albertinho July 29, 2011 06:58
in OpenFOAM-2.0.x is a Problem in the chtMultiRegionSimpleFoam-solver with the handling of liquids.
The Problem is in the fluid/hEqun.H, because since 1.7 the pressure p is replaced by rho/psi, and this leads to a SIGFPE because psi is 0 for a liquid.
Can anyone explain me this change?
Regards
Wolfgang
alberto July 30, 2011 03:06
You might want to report the problem on OpenCFD bug tracker: http://www.openfoam.com/mantisbt/main_page.php
albertinho August 2, 2011 09:58
Hello Alberto,
thanks for the hint, I've reported it and it is already changed.
But I already have a new problem. I want to make a transient Simulation of a water-glycol-cooler with the chtMultiRegion-solver. The initial state is a solution of the chtMultiRegionSimpleFoam. But it doesn't work, after about 2 time steps the solution diverges with very high temperatures. I tried to change the solution controls or the interpolation schemes, but nothing helps.
Then I looked into the code, again in the enthalpy equation, but this time of the chtMultiRegion-solver. I found the term DpDt wich is calculated in the pEqun.H - file.
Isn't it a term, which should only for compressible fluids in the enthalpy equation?
I commented the DpDt out in my own own version and it works.
Is this also a bug ?
Regards
Wolfgang
