August 1, 2011, 18:39 |
[solved]differentiation in one direction
Mieszko Młody
Dear Foamers,
Does anyone of you know what is the best way to dicsretize following problem: we have: f(x,y) -- scalar function we need: f_xxxx (fourth order) differentiation but only in one direction. i.e. laplacian(f) = f_xx + f_yy but I need only f_xx (in fact I need f_xxxx) Thanks ZM Last edited by ziemowitzima; August 4, 2011 at 14:16. Reason: solved |
August 2, 2011, 01:55 |
Fabian
You should use a difference quoutient, like you have propably seen for f_x. You can perform the difference quotient "four" times or you can have a look here (they have already done it for you):
http://en.wikipedia.org/wiki/Difference_quotient Probably it should be the best for you to read the whole article, but you can also jump ahead to: http://en.wikipedia.org/wiki/Differe....C5.83th_Order |
August 2, 2011, 11:10 |
Mieszko Młody
Thanks
This I know. I didn't put it explicit in my question but I need to know how to make it in OpenFOAM. -Best |
August 2, 2011, 17:52 |
Mieszko Młody
so far I found such explicit solution:
volVectorField gradT=fvc::grad(T); // (T_x, T_y) volScalarField Txxxx = gradT.component(0); // T_x gradT = fvc::grad(Txxxx); // (T_xx, T_xy) Txxxx = gradT.component(0); // T_xx gradT = fvc::grad(Txxxx); // (T_xxx, T_xxy) Txxxx = gradT.component(0); // T_xxx gradT = fvc::grad(Txxxx); // (T_xxxx, T_xxxy) Txxxx = gradT.component(0); // T_xxxx Maybe someone have some better idea ? Is it possible to descritize T_xxxx implicitly ? -ZM |
August 4, 2011, 12:24 |
Mieszko Młody
It seems that problem can be solved (after Akidess suggestion ):
"... it sounds like you want anisotropic diffusion - why not just pass a diffusion coefficient tensor to laplacian instead of a scalar?..." from: http://www.cfd-online.com/Forums/ope...-operator.html So, x - direction diffusion: DTe1D DTe1D [ 0 2 -1 0 0 0 0 ] (3e-02 0 0 0 0 0 0 0 0 ); x,y and - directions diffusion: DTe3D DTe3D [ 0 2 -1 0 0 0 0 ] (3e-02 0 0 0 3e-02 0 0 0 3e-02 ); for f_xxxx it can be done as follows : suppose we have equation f_xxxx = g(x,y), substitution: h = f_xx so we have two "one-directional" Poison equations to solve: h_xx = g(x,y) f_xx = h(x,y) in OF: fvm::laplacian(DTe1D, h) == g fvm::laplacian(DTe1D, f) == h |
one direction diff |
Flow Direction: normal to boundary!!! | Atit | CFX | 1 | August 2, 2015 13:42 |
Accelerate flow in one direction | JanR | FLUENT | 2 | January 19, 2011 15:52 |
[ICEM] Changing edge direction | la7low | ANSYS Meshing & Geometry | 2 | June 7, 2010 13:26 |
direction of porosity | shin | FLUENT | 0 | February 23, 2005 16:17 |
