-   -   Solving Problem with chtMultiRegionSimpleFoam (http://www.cfd-online.com/Forums/openfoam-solving/91621-solving-problem-chtmultiregionsimplefoam.html)
dongest August 17, 2011 03:46
Hello guys!
cann somebody help me,
Iam tryng to solve a heat transfer trough multiregion Fluid and Solid, but itīs not working.
this ist the error, I cann understand what happens!
Adding to rhos
Adding to cps
Adding to Ks
Adding to Ts
Time = 0
Solving for fluid region Fluid
DILUPBiCG: Solving for Ux, Initial residual = 0.93384871, Final residual = 0.00058842975, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.92335859, Final residual = 0.00052200336, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.9772765, Final residual = 0.00037334313, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.04792028, No Iterations 8
Min/max T:279.80643 923
GAMG: Solving for p_rgh, Initial residual = 0.99998585, Final residual = 0.0079283002, No Iterations 3
time step continuity errors : sum local = 118.94169, global = 3.4297456, cumulative = 3.4297456
Min/max rho:0.37915078 1.5674651
maxResidual: 1 convergence criterion: 0
Solving for solid region Solid
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/lib/linux64IccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/lib/linux64IccDPOpt/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam::triangleFuncs::intersectAxesBundle(Foam::Vec tor<double> const&, Foam::Vector<double> const&, Foam::Vector<double> const&, int, Foam::Field<Foam::Vector<double> > const&, double, Foam::Vector<double>&) in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/lib/linux64IccDPOpt/libmeshTools.so"
#4 Foam::triangleFuncs::intersectBb(Foam::Vector<doub le> const&, Foam::Vector<double> const&, Foam::Vector<double> const&, Foam::treeBoundBox const&) in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/lib/linux64IccDPOpt/libmeshTools.so"
#5 Foam::treeDataFace::overlaps(int, Foam::treeBoundBox const&) const in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/lib/linux64IccDPOpt/libmeshTools.so"
#6 Foam::indexedOctree<Foam::treeDataFace>::divide(Fo am::List<int> const&, Foam::treeBoundBox const&, Foam::List<Foam::List<int> >&) const in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/lib/linux64IccDPOpt/libmeshTools.so"
#7 Foam::indexedOctree<Foam::treeDataFace>::divide(Fo am::treeBoundBox const&, Foam::DynamicList<Foam::List<int>, 0u, 2u, 1u>&, int) const in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/lib/linux64IccDPOpt/libmeshTools.so"
#8 Foam::indexedOctree<Foam::treeDataFace>::indexedOc tree(Foam::treeDataFace const&, Foam::treeBoundBox const&, int, double, double) in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/lib/linux64IccDPOpt/libmeshTools.so"
#9 Foam::directMappedPatchBase::findSamples(Foam::Fie ld<Foam::Vector<double> > const&, Foam::List<int>&, Foam::List<int>&, Foam::Field<Foam::Vector<double> >&) const in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/lib/linux64IccDPOpt/libmeshTools.so"
#10 Foam::directMappedPatchBase::calcMapping() const in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/lib/linux64IccDPOpt/libmeshTools.so"
#11 Foam::turbulentTemperatureCoupledBaffleFvPatchScal arField::updateCoeffs() in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/lib/linux64IccDPOpt/libcompressibleRASModels.so"
#12 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricFi eld<double, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensionSet const&) in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64IccDPOpt/chtMultiRegionSimpleFoam"
#13 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacianUncorrected(Foam::GeometricFi eld<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/lib/linux64IccDPOpt/libfiniteVolume.so"
#14 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/lib/linux64IccDPOpt/libfiniteVolume.so"
#15 Foam::fv::laplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/lib/linux64IccDPOpt/libfiniteVolume.so"
#16 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64IccDPOpt/chtMultiRegionSimpleFoam"
#17 main in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64IccDPOpt/chtMultiRegionSimpleFoam"
#18 __libc_start_main in "/lib64/libc.so.6"
#19 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/CFD/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64IccDPOpt/chtMultiRegionSimpleFoam"
Floating point exception
thank you for any help.
Esther
raghu.tejaswi May 31, 2012 02:13
Is your problem resovled?
Were you able to solve your problem? Even I have the same problem. Is it the problem with the version or the software?
Raghu
