Max iteration exceeded
Old   August 24, 2010, 07:57
Default Max iteration exceeded
James
tookey_1989 is on a distinguished road
I'm having problems running a case involving relatively slow airflow (100m/s) with heat transfer. I'm trying to use rhoSimpleFoam which keeps spitting out an error for exceeding the max number of iterations.
Playing with the rho max and min values and the relaxation factors seems to change how long it takes for the error to appear, but didn't solve. I assume its due to a diverging solution.
I have gone back and looked at the boundary conditions several times and believe everything to be correct.
Can anyone please shed some light on whats going on here and a course of action to solve it.
Thanks for your help
James
Error:
Time = 48
smoothSolver: Solving for Ux, Initial residual = 0.015928, Final residual = 0.000956812, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.024058, Final residual = 0.00145616, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.0187837, Final residual = 0.0011141, No Iterations 4
DILUPBiCG: Solving for h, Initial residual = 0.0419237, Final residual = 0.00245746, No Iterations 6
GAMG: Solving for p, Initial residual = 0.00629986, Final residual = 0.000211266, No Iterations 2
time step continuity errors : sum local = 83.3833, global = 4.52158, cumulative = -350.1
rho max/min : 1.99995 0.00792878
ExecutionTime = 10.33 s ClockTime = 11 s
Time = 49
smoothSolver: Solving for Ux, Initial residual = 0.0150919, Final residual = 0.00090136, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.023529, Final residual = 0.00143824, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.0184029, Final residual = 0.00111382, No Iterations 4
DILUPBiCG: Solving for h, Initial residual = 0.0404039, Final residual = 0.00330438, No Iterations 12
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded
From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const
in file /home/james/OpenFOAM/OpenFOAM-1.7.x/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 67.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/james/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/james/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/home/james/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::correct() in "/home/james/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
in "/home/james/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/rhoSimpleFoam"
#5 __libc_start_main in "/lib64/libc.so.6"
at /usr/src/packages/BUILD/glibc-2.11.2/csu/../sysdeps/x86_64/elf/start.S:116
Aborted
tookey_1989 is offline   Reply With Quote
Old   August 24, 2010, 08:18
Christian Lucas
Chris Lucas is on a distinguished road
the problem is related to the thermo physical model you're using. The problem is that the function T (class specieThermo), which uses a Newton solver to get the temperature for a given enthalpy, can't find a solution within a 100 iteration.
The main reason for this problem might be that your pressure or enthalpy is out of bound.
Decrease the relaxation factors, and check the pressure and enthalpy before the error occurs
Regards,
Christian
Chris Lucas is offline   Reply With Quote
Old   August 25, 2010, 11:22
James
Thanks for your help chris,
I reduced the relaxation factors but hasn't seem to have solved the problem. Definitely pressure field thats going wrong but not sure how to fix.
I've uploaded my case (minus the mesh), if someone wouldn't mind having a quick look to see if i'm doing something stupid it would be greatly appreciated!
James
Old   August 26, 2010, 04:21
James
Fixed problem. I had a wave instability problem. I went back and looked at my relaxation factors and after some careful changes got stability.
Old   August 26, 2010, 07:32
Christian Lucas
would it be possible to upload the working case file?
By "wave instability problem", what exactly do you mean? Was the flow reflected at the outlet BC?
Regards,
Christian
Old   May 9, 2011, 12:00
Default FOAM FATAL ERROR: Maximum number of iterations exceeded
Tarak
Tarak is on a distinguished road
Hii,
I am facing a similar problem while running rhoPisoFoam. Can someone please let me know how to avoid it?
Thanks,
Tarak
Tarak is offline   Reply With Quote
Old   August 24, 2011, 05:43
Default problem in rhoPorusMRFSimpleFoam
suh
Suhas
suh is on a distinguished road
Hello Foamers,
I am using rhoPorousMRFSimpleFoam for compressor simulation. the mesh is came from starccm+ and checkMesh is ok. Then these are my boundary conditions. I am starting with very slow rotational velocity, i.e. w=1 rad/sec.
for p
inlet-zeroGradient,
outlet-fixedValue, $internalField
wall-zeroGradient internalField uniform 2e5;
for U
inlet-fixedValue, uniform (150 0 0)
outlet-zeroGradient,
wall-fixedValue, uniform (0 0 0) internalField uniform (1 10 10)
for T
inlet-totalTemperature, T0 uniform 300, gamma 1.4
outlet-inletOutlet, value $internalField, inletValue $internalField
wall-zeroGradient, internalField uniform 298;
for mut
inlet-calculated uniform 0,
outlet-calculated uniform 0,
wall-mutkWallFunction uniform 0, internalField uniform 0.018;
for k
inlet-fixedValue, uniform 70
outlet-zeroGradient
wall-compressible: :kqRWallFunction uniform 7, internalField uniform 7;
for epsilon
inlet-fixedValue, uniform 19222.91
outlet-zeroGradient
wall-compressible: :epsilonWallFunction uniform 1922.291, internalField uniform 7;
for alphat
wall-alphatWallFunction uniform 0, internalField uniform 0;
my relaxation factors from fvSolution files are
p 0.1;
rho 1;
U 0.3;
"(k|epsilon)" 0.5;
h 0.5;
and rhomax - 1.9
rhomin - 0.6
and
thermoType hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>;
mixture
specie
nMoles 1;
molWeight 28.9;
thermodynamics
Cp 1007;
Hf 2.544e+06;
transport
mu 0.1835e-04;
Pr 0.72;
and I am getting this error after 200 iterations.
From function specieThermo<Thermo>::T(scalar f, scalar T0, scalar (specieThermo<Thermo>::*F)(const scalar) const, scalar (s pecieThermo<Thermo>::*dFdT)(const scalar) const) const
in file /opt/software/OpenFOAM/OpenFOAM-2.0.x/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 67.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/share/openfoam/2.0/OpenFOAM/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/share/openfoam/2.0/OpenFOAM/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#2 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::ca lculate() in "/share/openfoam/2.0/OpenFOAM/platforms/linux64Gcc45DPOpt/lib/libbasicThermophysicalModels.so"
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::co rrect() in "/share/openfoam/2.0/OpenFOAM/platforms/linux64Gcc45DPOpt/lib/libbasicThermophysicalModels.so"
#4 main in "/share/openfoam/2.0/OpenFOAM/platforms/linux64Gcc45DPOpt/bin/rhoPorousMRFSimpleFoam"
#6 Foam::UOPstream::write(char) in "/share/openfoam/2.0/OpenFOAM/platforms/linux64Gcc45DPOpt/bin/rhoPorousMRFSimpleFoam"
Abort
Please tell me where I am going wrong.
Is anybody using rhoPorousMRFSimpleFoam?
Regards
Suhas
suh is offline   Reply With Quote
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 22:30
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
5.7.1 solver doing max coeff loops. Stevie Wonder CFX 5 July 5, 2005 12:31
the max iteration numbers in one time step yangqing FLUENT 4 February 1, 2002 10:24
