Problem with both parallel and serial
Old   September 30, 2011, 17:27
Default Problem with both parallel and serial
Chenguang Li
lcg44 is on a distinguished road
Hi, when I run interFoam I meet this error, both in parallel and serial, I can't understand what causes this. Could you help me?
#0 Foam::error:rintStack(Foam::Ostream&) in "/work/c28li/hound/OpenFOAM201/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/work/c28li/hound/OpenFOAM201/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/work/c28li/hound/OpenFOAM201/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/work/c28li/hound/OpenFOAM201/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/work/c28li/hound/OpenFOAM201/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/work/c28li/hound/OpenFOAM201/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/work/c28li/hound/OpenFOAM201/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#8 main in "/work/c28li/hound/OpenFOAM201/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/interFoam"
#9 __libc_start_main in "/lib64/libc.so.6"
#10 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/work/c28li/hound/OpenFOAM201/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/interFoam"
/var/spool/torque/mom_priv/jobs/335481.saw-admin.saw.sharcnet.SC: line 3: 29480 Floating point exceptioninterFoam
Thank you very much.
lcg44 is offline   Reply With Quote
Old   October 1, 2011, 15:02
Alberto Passalacqua
The provided information does not seem sufficient. When does this happen? If it is at the beginning of the simulation, and the tutorial runs fine, probably you should check the setup of your case.
Alberto Passalacqua
Old   October 1, 2011, 17:13
Retired Super Moderator
Bruno Santos
Greetings Chenguang Li and welcome to the forum!
I had that problem, namely with "GAMGSolver::scalingFactor" or something similar to that the other day, and I vaguely remember that the problem was related to an excessively high maxCo value in "system/controlDict". Either that or I wasn't using the automatic deltaT adjustment.
If you had posted the lines of the latest 1 or 2 iterations, it would be easier to figure out if this was the issue or not.
The other possibility is that the mesh is damaged. Run checkMesh to confirm this.
Yet another possibility is that the parameters for using GAMG aren't sufficient for the complexity of your mesh... but unfortunately I don't know enough about it to be of any help with that
Best regards,
Bruno
edit: Hi Alberto, didn't see you had already posted, because I had an old version of this page
Old   October 1, 2011, 22:50
Chenguang Li
Thank you very much. I'll try to find which one is the right reason as you suggested.
I'm so excited that my question was answered by you so quickly. I love this forum!
different results between serial solver and parallel solver wlt_1985 FLUENT 11 October 12, 2018 08:23
Serial OK parallel failsmesh conversion problem r2d2 OpenFOAM Running, Solving & CFD 15 July 31, 2008 15:04
Help: Serial code to parallel but even slower Zonexo Main CFD Forum 4 May 14, 2008 10:26
Problem with Parallel not with Serial iyer_arvind OpenFOAM Running, Solving & CFD 0 September 18, 2006 06:03
parallel mode - small problem? co2 FLUENT 2 June 1, 2004 23:47
