October 19, 2011, 12:55 |
Porosity changing in space and time
Greetings, gentlemen.
Is there any way to assign to each cell of the mesh the porosity coefficients and change these values each time step? In web I found Kamil Kwiatkowski presentation, where it was done by means some "setPorosity" function. I didn't find this function either in OF-1.7.1 or in OF-1.6-ext sources. Please, help with this problem Best regards, Aleksey. |
June 15, 2013, 07:39 |
#2 | |
Himanshu Sharma
were you able to simulate the problem you have posted that the porosity decreases with respect to time and space.? I am also working on some problem which require this simulation to be performed in which pororsity changes.I will be thankful to you if you provide some guidance if you have solved the issue Regards Himanshu Sharma |
porosity |
Variable BC in time and space for transient run | Porry | CFX | 2 | February 21, 2012 09:38 |
Numerical Weather Modelling : Time and space resolution issues | chriswatt | Main CFD Forum | 0 | February 15, 2011 21:32 |
Richardson Extrapolation to check time and space convergence | Hooman | Main CFD Forum | 0 | December 29, 2010 08:19 |
Time and Space Derivatives. | beezee99 | FLUENT | 0 | August 19, 2010 01:34 |
Space and time discretization of Euler equation | Hooman | Main CFD Forum | 2 | June 6, 2010 08:30 |
