Problem with dieselFoam and themophysical properties
I just did a pull from the repository and can no longer run anything in dieselFoam. Even the tutorial crashes with the following:
--> FOAM FATAL ERROR: |
Hi Marco,
Yeah, I know, Henry Weller has been tweaking the code to respect physics a bit better: http://www.openfoam.com/mantisbt/view.php?id=327 - the tutorials still need fixing as mentioned on comment #777: http://www.openfoam.com/mantisbt/view.php?id=327#c777 I think that you can go back to a safer place by running: Code:
git checkout 2b11286dad626d4f6a35379eeda0f29b0ee5ac23 You can check what they've been doing before doing a "git pull" by seeing here first: https://github.com/OpenFOAM/OpenFOAM-2.0.x/commits/ Best regards, Bruno |
Hi everyone,
I have the same problem with my newly installed OF 2.0.x. :( Code:
--> FOAM FATAL ERROR: http://www.tfd.chalmers.se/~hani/kur...OwnLaptop.html I tried the restore command Bruno has offered, but that avenue failed too! :confused: Quote:
I truly appreciate it, if anyone can help me to resolve this error?! Thanks in advance, Jalal |
Greetings Jalal,
Did you do any changes to the code in the OpenFOAM-2.0.x folder, before running that command? If so, run the following commands: Code:
git stash Code:
./Allwmake Bruno |
Hi Bruno,
Thanks for your immediate follow up. As for your following question: Quote:
As for changes to the code in the OF-2.0.x folder: Quote:
Today, I went to the openFOAM-2.0.x directory, and issued the restore command you provided in your old post. This is what I witnessed: Code:
Note: checking out '2b11286dad626d4f6a35379eeda0f29b0ee5ac23'. Code:
--> FOAM FATAL ERROR: I tried the new restore and make commands you proposed: Quote:
jalal@ubuntu:~/OpenFOAM/OpenFOAM-2.0.x$ git stash I hope this fixes the problem.:( Jalal |
Hi Jalal,
OK, then the problem was that you only did the git checkout. Without re-building OpenFOAM, the libraries and applications could not reflect the modified source code. I didn't mention the need to run Allwmake because it's implied when using the git version of OpenFOAM ;) To speed up the build process, run this command before Allwmake: Code:
export WM_NCOMPPROCS=4 Best regards, Bruno |
Thanks Bruno,
I didn't know about the necessity of Allwmaking after gitting! I didn't have the chance to try your multiprocessor speedup command, because I had already issued the Allwmake. Anyway, now dieselFoam works and I do not see those strange janafThermo errors. So happy!:p:) Thanks again, Jalal |
Hi Foamers,
I have used the solution proposed by Bruno and it worked on my laptop. However, when I did the exact same thing on my workstation and I received the error below when I run the case. Evolving Spray Solving chemistry #0 Foam::error:: printStack(Foam::Ostream&) in "/home/kmpan/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/home/kmpan/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 exp in "/lib/x86_64-linux-gnu/libm.so.6"F #4 Foam::ReversibleReaction<Foam::sutherlandTransport <Foam::specieThermo<Foam::janafThermo<Foam:: perfectGas> > >, Foam::FallOffReactionRate<Foam::ArrheniusReactionR ate, Foam::TroeFallOffFunction> >::kf(double, double, Foam::Field<double> const&) const in "/home/kmpan/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so" #5 Foam::ODEChemistryModel<Foam:: psiChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam: :janafThermo<Foam:: perfectGas> > > >::omega(Foam::Reaction<Foam::sutherlandTransport< Foam::specieThermo<Foam::janafThermo<Foam:: perfectGas> > > > const&, Foam::Field<double> const&, double, double, double&, double&, int&, double&, double&, int&) const in "/home/kmpan/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libchemistryModel.so" #6 Foam::ODEChemistryModel<Foam:: psiChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam: :janafThermo<Foam:: perfectGas> > > >::omega(Foam::Field<double> const&, double, double) const in "/home/kmpan/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libchemistryModel.so" #7 Foam::ODEChemistryModel<Foam:: psiChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam: :janafThermo<Foam:: perfectGas> > > >::derivatives(double, Foam::Field<double> const&, Foam::Field<double>&) const in "/home/kmpan/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libchemistryModel.so" #8 Foam::ODESolver::solve(Foam::ODE const&, double, double, Foam::Field<double>&, double, double&) const in "/home/kmpan/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libODE.so" #9 Foam::ode<Foam::ODEChemistryModel<Foam:: psiChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam: :janafThermo<Foam:: perfectGas> > > > >::solve(Foam::Field<double>&, double, double, double, double) const in "/home/kmpan/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libchemistryModel.so" #10 Foam::ODEChemistryModel<Foam:: psiChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam: :janafThermo<Foam:: perfectGas> > > >::solve(double, double) in "/home/kmpan/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libchemistryModel.so" #11 in "/home/kmpan/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/bin/dieselFoam" #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 in "/home/kmpan/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/bin/dieselFoam" Floating point exception (core dumped) Both my laptop and workstation are running with OF20x and the test case is exactly the same. :confused: FYI, there are many fall-off reactions in my chem.inp, defined by by LOW and TROE, for example: C2H2+H(+M)<=>C2H3(+M) 5.600E+12 0.000 2.400E+03 LOW / 3.8000E+40 -7.2700E+00 7.2200E+03 / TROE / 7.5100E-01 9.8500E+01 1.3020E+03 4.1670E+03 / H2/2/ H2O/6/ CO/1.5/ CO2/2/ CH4/2/ C2H6/3/ When I commented out LOW and/or TROE, the case can be run but apparently, the solution is just not right. :p Can anyone please give some advice regarding this issue? Many thanks in advance! Best regards, Pang. |
Greetings Pang,
Try this on both machines: Code:
dieselFoam -help Code:
Using: OpenFOAM-2.0.x (see www.OpenFOAM.org) Best regards, Bruno |
Hi Bruno,
Sorry for the late reply. I have run dieselFoam -help on both of the machines and they did show 2.0.x-2b11286dad62. However, one of them gives the problem that I mentioned earlier. Do you have any clue? It's just confusing me. :confused: Many thanks for your help. :) Best regards, Pang |
Hi Pang,
Try running one of the tutorial cases from 2.0.x that use dieselFoam. If it also crashes, try running the following commands for rebuilding OpenFOAM 2.0.x: Code:
foam Best regards, Bruno |
Thanks again Bruno.
In fact it didn't crash with the tutorial case and when I use some other chemical mechanisms. I tried to recompile OF too but it doesn't solve the problem. That's weird. Emm... :mad: Best regards, Pang |
Hi Pang,
A few ideas come to mind:
Bruno |
Hi Bruno,
Million thanks for the suggestion. Unfortunately, the remote access to my office workstations is down. :mad: I can't test them out throughout the weekend. I'll test next week and share my experience here by then. Thanks again and have a nice weekend! Best regards, Pang. |
Hi Bruno,
I have checked through according to your suggestions: 1) Do both machines use the x86_64 architecture? Because if one of them is a 32bit machine, or has a i686 Linux Distribution installed, that might indicate that the problem is related to small math differences. A: Yes, both are running with the x86_64 architecture. 2) The libraries used on the system might be different. Run the following command on both machines: Code: ldd $(which dieselFoam) Check if there are differences between the two outputs. A: All the libraries are same but the alphanumeric at the end of each line is different, does it matter? ----- Eg: libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f16723bc000) 3) Check if the binary is exactly the same, location-wise: A: The binary is exactly the same. 4) Are you 100% certain that the cases are identical on both machines? A: Yes, I'm sure that the cases are identical. 5) Does your case have any "libs ();" or function object entries in "system/controlDict"? A: No, I didn't include that function objection there. 6) Have you modified anything or any file inside the folder "OpenFOAM-2.0.x/etc"? A: I don't think I did anything to any files in that folder. 7) Does the folder "~/.OpenFOAM" exist? If so, are there any stray files inside it? Notice that there is a dot symbol before "OpenFOAM"! This folder is for personal configurations. A: I have checked under my personal directory and I don't see any ~/.OpenFOAM there. 8) Have you built any custom solvers or libraries on one of the machines? A: I have quite a bit of different custom solvers and libraries in both of the machines but as far as I remember, I didn't modify anything on the default dieselFoam. By the way, one of my machine (of that which is free from this problem) is running with Ubuntu 11.10 while the one faces the problem is running with Kubuntu 12.04. Will this difference give the problem? Many thanks again. Best regards, Pang |
Hi Pang,
7) Confirm with the following command, just in case: Code:
ls -l ~/.OpenFOAM Code:
mv ${FOAM_USER_APPBIN} ${FOAM_USER_APPBIN}_backup
As for one being Ubuntu 11.10 and the other Kubuntu 12.04 - there are a few possibilities:
Bruno |
Hi Bruno,
Sorry for the late reply. I was busy with something else. 7) Tried using 'ls -l ~/.OpenFOAM' and it returned with 0 found. 8) I can't test these now cause I'm running some cases with the solvers. I'll test it as soon as I finish those simulations. Emm, for some reasons, it works with 11.10 but not 12.04 in my case - weird enough. Many thanks for the support again. I shall continue to find out the reason behind soon. :o Best regards, Pang. |
