parallel execution not starting
I have a clean install of 2.0.x and single processor operations are working without any issues. If i try to use any solver or utility with the -parallel flag, I get no execution, no errors and no output to the terminal / log file. For example: mpirun -np 6 pisoFoam -parallel > logRun& or foamJob -p pisoFoam both return empty logs and 0 cpu activity. If i try: mpirun -np 6 pisoFoam -parallel without dumping into a log, nothing is shown after executing the command, and I can ctrl+c to see: mpirun: killing job... Any ideas? |
Can you check if you can run a trivial hello world c++ program using mpirun first?
Ganesh,
Here is a sample hello world which utilizes mpi. Found online: Code:
#include <stdio.h> mpircc -o hello2 hello2.c without any errors an executable is created. Same issues when I try to run this using: mpirun -np 2 hello2 No errors, but also no execution. This exec also does not run in serial using just ./hello2, but I am not sure as to whether it should with the MPI libs in it. I also reran ./Allwmake in the main OF dir just to make sure everything was compiled correctly. I am using the openmpi that came with 2.0.x (mpirun (Open MPI) 1.5.3). |
