OpenFoam for aeroacoustics
Like Tree4Likes
  • 2 Post By richard
  • 2 Post By richard
Old   November 2, 2007, 05:00
Default Hi I am new to OpenFoam. Is
tog
Guillaume Alleon
tog is on a distinguished road
Hi
I am new to OpenFoam. Is it well suited for low Mach aeroacoustic problems ?
Is there anybody having done some tests in this area ?
Best Regards
Guillaume
tog is offline   Reply With Quote
Old   November 2, 2007, 05:14
Default Hello, I would be intereste
Guido Adriaensen
guido_adriaensen is on a distinguished road
I would be interested in this as well.
I did find a short reference to OF en aeroacoustics, but could not find any comparison with other experiments and/or other CFD solvers.
Guido
guido_adriaensen is offline   Reply With Quote
Old   November 2, 2007, 05:58
Default I've done some validations for
lillberg's Avatar
Eric Lillberg
lillberg is on a distinguished road
Send a message via Skype™ to lillberg
I've done some validations for vortex induced acoustic resonance in deep cavities at Ma 0.1 using LES (the coodles code). The results agree well with the experiments by Yang, Y. in his PhD thesis "Generation of Tones due to Grazing Shear Flow Past a Deep Cavity", Lehigh University (2005)).
For general acoustic simulations the fluctuating pressure field from an LES is well suited as source terms for far field simulations. There is, however, no OF code readily available for far field predictions.
Regards
//Eric
lillberg is offline   Reply With Quote
Old   November 6, 2007, 19:31
Default Hi, I've just finished doin
Richard Jones
richard is on a distinguished road
I've just finished doing a reasonable amount of work on cylinder aeroacoustics, using both icoFoam and turbFoam to get source data for use in Curle's method - also investigated periodic holes as a noise reduction mechanism. These worked well, but LES would be better. Drop me an email if you would like some results.
With any luck, I'll be starting my PhD in January on shape optimisation for reduced aerofoil trailing edge noise, using OpenFOAM.
I would love to get in contact with anyone else using OpenFOAM for aeroacoustics..
Regards,
Richard
richard is offline   Reply With Quote
Old   July 20, 2008, 23:58
Default Hi Richard I want to know the
YekaniYasari
yekaniyasari is on a distinguished road
Hi Richard
I want to know the ability of OpenFOAM in aeroacoustics problems. In the source of this software I could not find any direct solver for these applications. Is it necessary to change the OpenFOAM solver for this goal? If you have any solved problem, I appreciate, if it is possible for you to send it for me.
Regards
yekaniyasari is offline   Reply With Quote
Old   July 21, 2008, 00:20
Default Hi Yekani, Your right there
Richard Jones
Hi Yekani,
Your right there isn't a direct solver for aeroacoustics (except DNS of course!), but OF is great for getting source data to use in uncoupled computations. (e.g. turbulent stresses to use in lighthill's equn or liftDrag to get body forces for compact noise sources) but you would need to make some post-processing code to get the acoustic field (LEE or otherwise) from this source data.
Feel free to email me and we can chat about it further
Richard.
Old   July 7, 2010, 10:37
anning
412412can is on a distinguished road
Hi Richard
if i have already got the lift/drag from OF,how should i use them to compute the body forces for compact noise sources.
Regards
412412can is offline   Reply With Quote
Old   August 30, 2010, 21:47
Default ....
Mohammad.R.Shetab
mrshb4 is on a distinguished road
Hi Richard
I'm just starting my master thesis on noise prediction of centrifugal fans using openfoam.As my first step I will use RANS to find pressure fluctuations. It would be great to be in touch with you.
here is my email:
mrshb4@gmail.com
I wonder if I could have your email too!!!
Best regards
Mohammadreza Shetab
mrshb4 is offline   Reply With Quote
Old   November 7, 2011, 12:56
Default Aeroacoustics
Francesca
Francesca Scaramuzzino is an unknown quantity at this point
Hi Richard,
I wonder if you could chat with me about aeroacoustics because I would like to adopt OpenFoam for thermoacoustics interactions but I don't know neither how I could use it for aeroacoustics problems..so I give you my e-mail adress: francesca.scaramuzzino86@gmail.com...I would be very happy if you could contact me.
Best Regards
Francesca
Francesca Scaramuzzino is offline   Reply With Quote
aeroacoustics Mr Niten Mistry Siemens 0 October 8, 2004 10:23
aeroacoustics carno Siemens 2 October 30, 2003 06:49
Aeroacoustics jonathan FLUENT 0 February 3, 2002 23:55
CFD and Aeroacoustics Alfredo Alonso Main CFD Forum 10 October 13, 1998 09:52
