recnice |
November 8, 2011 02:38 |
Convergence Problems using Spalart Allmaras
i'm trying to investigate an airfoil under different angles of attack.
I'm using the SimpleFoam solver with the Spalart Allmaras turbulence modell. I have a Re-Number = 2e06.
For angels of 0 and 5 degrees, there is a good convergence, but for higher angles of attacks, like 10 and 15 degrees, there is no steady-state convergence.
I don't understand the problem? Is there something wrong with my case (b.c., solver ??)
I hope someone can help!
Denis
| \\ / O peration | Version: 2.0.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver GAMG;
tolerance 1e-06;
relTol 1e-8;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration true;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
U
solver smoothSolver;
nSweeps 2;
tolerance 1e-08;
relTol 1e-12;
nuTilda
nSweeps 2;
tolerance 1e-08;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
residualControl
p 1e-5;
U 1e-5;
nuTilda 1e-5;
relaxationFactors
default 0;
p 0.3;
U 0.7;
nuTilda 0.7;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application simpleFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 800;
deltaT 1;
writeControl timeStep;
writeInterval 200;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss linearUpwind grad(U);
div(phi,nuTilda) Gauss linearUpwind grad(nuTilda);
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
laplacian(1,p) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
Outflow
type freestreamPressure;
Inflow
Finne-Wall
type zeroGradient;
frontAndBack
type empty;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (21.465 5.7515 0);
boundaryField
Inflow
type freestream;
freestreamValue uniform (21.465 5.7515 0);
Outflow
type freestream;
Finne-Wall
type fixedValue;
value uniform (0 0 0);
frontAndBack
type empty;
FoamFile
version 2.0;
format ascii;
object nut;
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0.14;
boundaryField
Inflow
type freestream;
freestreamValue uniform 0.14;
Outflow
type freestream;
Finne-Wall
type nutUSpaldingWallFunction;
value uniform 0;
frontAndBack
type empty;
FoamFile
version 2.0;
format ascii;
object nuTilda;
boundaryField
Inflow
type freestream;
Outflow
type freestream;
Finne-Wall
type fixedValue;
value uniform 0;
frontAndBack
type empty;
