-   -   Visualization of rotor's induced flow (http://www.cfd-online.com/Forums/openfoam-solving/94202-visualization-rotors-induced-flow.html)
JulytoNovember November 9, 2011 04:08
1 Attachment(s)
Using MRFSimpleFoam, I've simulated the forces on a co-axial helicopter rotor system. However, I would like to view the airflow induced by the system. I'm working in 3D and using actual rotor data for the mesh using blockmesh. I've tried many things, nothing as worked for me. How can I view the the changes to the atmosphere caused by my rotor? :confused: Here is 2D picture of the rotor, just to give an idea of what it looks like. Keep in mind it is a 3D mesh. I lowered the quality of the mesh to decrease simulation time. Thank You.
JulytoNovember April 23, 2012 20:07
I'm using pimpleDyMFoam, I changed to a single rotor for now. The rotor is in a cylinder with 2 inlets (top and bottom). Everything else runs fine just no induced flow. Could someone tell me what I'm doing wrong? The don't really understand the fvsolution and fvshemes, I taught myself OpenFOAM, so I'm still learning.
HTML Code:
| \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox          |
|  \\    /  O peration    | Version:  2.0.1                                |
|  \\  /    A nd          | Web:      www.OpenFOAM.com                      |
|    \\/    M anipulation  |                                                |
FoamFile
    version    2.0;
    format      ascii;
    class      volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField  uniform 0;
boundaryField
    rotor
        type            zeroGradient;
    top
    type        zeroGradient;
    bottom
    type        zeroGradient;
    wall
    type        fixedValue;
    value        uniform 0;
    insideSlider
    type ggi;
    value    uniform 0;
    outsideSlider
    type ggi;
    value    uniform 0;
    inlets
    type        zeroGradient;
HTML Code:
FoamFile
    version    2.0;
    format      ascii;
    class      volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField  uniform (0 0 0);
boundaryField
    rotor
        type            movingRotatingWallVelocity;
    centre (0 0 0);
    rpm 450;
    axis (0 1 0);
        value          uniform (0 0 0);
    top
    type        inletOutlet;
    inletValue    uniform (0 -5 0);
    bottom
    type        inletOutlet;
    inletValue    uniform (0 5 0);
    wall
        type            fixedValue;
    insideSlider
    type ggi;
    outsideSlider
    type ggi;
    inlets
    type        pressureInletOutletVelocity;
HTML Code:
| \\      /  F ield        | OpenFOAM Extend Project: Open Source CFD        |
|  \\    /  O peration    | Version:  1.6-ext                              |
|  \\  /    A nd          | Web:      www.extend-project.de                |
FoamFile
    version    2.0;
    format      binary;
    class      dictionary;
    location    "system";
    object      fvSolution;
solvers
    pcorr
        solver          PCG;
        preconditioner  DIC;
        tolerance      0.01;
        relTol          0;
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance      1e-06;
        relTol          0.05;
    pFinal
        solver          PCG;
        preconditioner  DIC;
        tolerance      1e-06;
        relTol          0;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance      1e-05;
        relTol          0;
    UFinal
        solver          PBiCG;
        tolerance      1e-05;
        relTol          0;
PIMPLE
    nOuterCorrectors    2;
    nCorrectors        1;
    nNonOrthogonalCorrectors 0;
    pRefPoint        (0 0 0);
    pRefValue        0;
HTML Code:
FoamFile
    version    2.0;
    format      binary;
    class      dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default        Euler;
gradSchemes
    default        Gauss linear;
    grad(p)        Gauss linear;
divSchemes
    default        none;
    div(phi,U)      Gauss linear;
    div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
    default        none;
    laplacian(nu,U) Gauss linear corrected;
    laplacian(rAU,pcorr) Gauss linear corrected;
    laplacian(rAU,p) Gauss linear corrected;
    laplacian(diffusivity,cellMotionU) Gauss linear uncorrected;
    laplacian(nuEff,U) Gauss linear uncorrected;
interpolationSchemes
    default        linear;
    interpolate(HbyA) linear;
snGradSchemes
    default        corrected;
fluxRequired
    default        no;
    pcorr          ;
    p              ;
