August 24, 2011, 08:17 |
IcoFoam Divergent Duct Simulation Problem
Hi dear foamers,
I'm running a simple 2D subsonic divergent duct. According to the Gas Dynamics, Velocity decreases, and Pressure increases while the cross sectional area increases. But when IcoFoam runs, velocity decreases but Pressure decreases. The result are shown in attachment. So I try to change boundary conditions in pressure boundary field, but didn't work. So can u give me some advise to get correct one? BC are Inlet, Outlet, Wall and Symmentry. Velocity boundaryField { Inlet { type fixedValue; value uniform (5 0 0); } Outlet { type zeroGradient; } Wall { type fixedValue; value uniform (0 0 0); } Symmetry { type symmetryPlane; } } -------------------------------------------------------------------------------------------------------------- For pressure boundaryField { Inlet { type zeroGradient; } Outlet { type fixedValue; value uniform 0; } Wall { type zeroGradient; } Symmetry { type symmetryPlane; } } |
November 9, 2011, 22:22 |
Alberto Passalacqua
Rep Power: 36 |
The case does not contain the "constant" directory.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
Problem with interface in a wind turbine simulation | be_inspired | FLUENT | 2 | March 7, 2011 23:46 |
Problem Concerning free surface wave simulation | michaels | STAR-CCM+ | 3 | February 25, 2011 07:28 |
Problem with using icoFoam for flow in a straight tube | edificelp | OpenFOAM | 4 | February 11, 2011 03:27 |
Urgent; convergence problem in MRF simulation | Mansureh | ANSYS | 4 | February 2, 2011 06:00 |
mass balance problem in transient simulation | nana84 | CFX | 2 | April 15, 2010 19:53 |
