-   -   move wall and refine mesh at fluid interface (http://www.cfd-online.com/Forums/openfoam-solving/94305-move-wall-refine-mesh-fluid-interface.html)
Jimbomet November 11, 2011 10:38
I'm trying to solve a multiphase problem with a wall that simply moves in x direction, using interDyMFoam and I used, in the dynamicMeshDict :
dynamicFvMesh dynamicMotionSolverFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solver velocityComponentLaplacian x;
diffusivity directional (200 1 0)
but now I want to introduce also a refinement of the mesh near to the interface of two fluids, say in the same file:
dynamicFvMesh dynamicRefineFvMesh;
dynamicRefineFvMeshCoeffs
refineInterval 1;
field alpha1;
lowerRefineLevel 0.001;
upperRefineLevel 0.999;
unrefineLevel 10;
nBufferLayers 1;
maxRefinement 2;
maxCells 500000;
correctFluxes
(phi
U)
dumpLevel true;
and I don't know how to impose the two different dynamic meshing together...can someone give me an idea?? thanks a lot, I can't solve this problem ...
Prosper March 4, 2014 14:00
Same question!!!
refineInterval 1;
field alpha1;
unrefineLevel 10;
nBufferLayers 1;
maxRefinement 2;
maxCells 500000;
correctFluxes
(phi
U)
dumpLevel true;
wyldckat March 4, 2014 14:29
Greetings to all!
I don't think OpenFOAM has this implemented yet. Well, at least not in interDyMFoam.
In theory, it's just a matter of creating a custom solver based on interDyMFoam, adding code for performing a second dynamic mesh operation, on top of the first one.
Best regards,
Bruno
Prosper March 4, 2014 14:33
Thanks! Will try that.
Originally Posted by wyldckat (Post 478083)
Greetings to all!
Best regards,
Bruno
BielawskiR October 17, 2014 12:12
Will that method only work with r-refinment where the number of cells does not change?
wyldckat October 18, 2014 13:16
Greetings BielawskiR and welcome to the forum!
:confused: Sorry, but I don't understand what exactly you're asking about. Can you please be more specific?
Best regards,
Bruno
BielawskiR December 4, 2014 14:17
When the number of cells changes you often have to edit the solver/utility because a lot of them were written with the assumption that the number of cells is constant.
For example I was just working on getting ACMI to work with mesh refinement and mesh motion. To make them work together you need to have it use the most recent data for all ACMI boundaries. In the default algorithm it only looks at the current size of one boundary and if the other boundaries have new cells it fails.
However mesh motion and refinement both edit the points so they may work out of the box together.
I think this is a little bit more clear.
