how to define this PDE:Uxx-a^2Ut+A*exp(-a*x)=0 |
November 15, 2011, 09:05 |
zdong
Rep Power: 14 |
hello every one, i need your help now.
i'm tring to solve this PDE:Uxx-a^2Ut+A*exp(-a*x)=0 with openFoam, after copying the solver "laplacianFoam"to my own directory and changing it to myLaplacianFoam, i add two lines in the "main" function in the myLaplacianFoam.c like this: volVectorField centers = T.mesh().C(); volScalarField x = (centers&vector(1,0,0)); then define the equation : -fvm::ddt(sqr(a),T) - fvm::laplacian(T) == -A*exp(-a*x); the parameters A and a are defined in creatFiled.H and in transportProperties dictionary file within the case directory. when i try to use this solver, the error echoed : Argument of trancendental function not dimensionless how could i deal with this problem? shoul i make the argument in the exp() function dimensioniess or define the A*exp(-a*x) as a volScalarField "f" in createFiled.H,and give "f" the original and boundary value in the case directory when i need to run the solver? by the way ,if i want to utilize openFoam to solve some typical PDEs,where can i find the reference source? thanks for your attention. |
HELP----Surface Reaction UDF | Ashi | Fluent UDF and Scheme Programming | 1 | May 19, 2020 21:13 |
Installing OF 1.6 on Mac OS X | gschaider | OpenFOAM Installation | 129 | June 19, 2010 09:23 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 10:19 |
