-   -   OpenFOAM cluster (http://www.cfd-online.com/Forums/openfoam-solving/94430-openfoam-cluster.html)
lordvon November 15, 2011 18:53
OpenFOAM cluster
I am trying to run 1.5-dev ggi in an Ubuntu lan cluster by ethernet switch.
I have been trying to follow these instructions posted on another thread:
1 - In version 1.7.1, put the line . / Opt/openfoam171/etc/bashrc AS FIRST LINE in the files sudo gedit /etc/profile , sudo gedit ~/.Profile and gedit ~/.Bashrc. In all machines in the network you will use.
2- In file machines (which can be created in the tutorial) put the machine name followed by how many processors are used on this machine.
Example
ubuntu1
ubuntu2 cpu = 2
3 - Give decomposePar in all machines.
4- Type mpirun --hostfiles machines -np <number of prpcessos> <solver name> - parallel
But I can't get it to work. I replaced the ". /opt/..." with "/usr/lib/OpenFOAM-1.5-dev/etc/bashrc" for 1.5-dev.
The error is:
mpirun was unable to launch the specified application as it could not find an executable:
Executable: --hostfiles
Node: myName-desktop
while attempting to start process rank 0.
Has anybody successfully run openfoam 1.5-dev successfully in a cluster with similar instructions?
