November 16, 2011, 10:52 |
difficultis using cavitatingFoam
Dear all,
i'm trying to simulate cavitating flow around circular cylinder using cavitatingFoam. The case running shows a little bit instable, i mean it easily break down. It seems that difficulties lie in solving p equation. the result shows that very high or low pressure value points exist where there is high velocity gradien. i wonder if anyone have simulated that flow(maybe around foil) or anyone meet similar difficulties in using cavitatingFoam. anyway,i know fabian peng Karrholm did a lot of simulation by cavitatingFoam, if anyone could tell me how to contact him(by any means). Thank you all guys。 |
February 1, 2012, 12:36 |
Any progress?
Tom
Rep Power: 14 |
Alexanger,
I would be interested to know if you have made any progress on this front? I am currently trying to evaluate the pros and cons of cavitatingFoam for diesel injectors. I know Karrholm did some work on this front, however looking through his PhD dissertation, stuck to rather low injection pressures, ~7 MPa, where as I am looking to investigate 150 MPa injections. I have been sucessful in setting the injection pressure to 150 MPa, but so far I have only had stability when the ambient pressure is 50 MPa. I am trying to get down to 6 MPa, so still a ways to go. While both my work and Karrholms was focused on internal flows, it may have some crossover with the external flows you have been investigating. |
mapping of pressure field (simplefoam to cavitatingFoam) | siddharameshwara | OpenFOAM Running, Solving & CFD | 14 | February 15, 2011 08:59 |
cavitatingFoam error..... | siddharameshwara | Main CFD Forum | 0 | October 15, 2010 02:56 |
How to add temperature to cavitatingFoam solver | chodki-c | OpenFOAM | 9 | September 30, 2010 11:21 |
Negative Total Pressure in cavitatingFoam RAS/Throttle Case in OF 1.6 | danishdude | OpenFOAM Running, Solving & CFD | 1 | September 6, 2010 05:36 |
Problem with cavitatingFoam | clo | OpenFOAM Running, Solving & CFD | 1 | June 7, 2007 11:53 |
