icoFoam crash with unreasonable velocity.
Old   November 19, 2011, 20:24
Default icoFoam crash with unreasonable velocity.
Bylund is on a distinguished road
A question from an inexperienced OpenFOAM user.
I am playing around with a simple manifold design and icoFoam.
After 10 time steps everything looks more or less ok, but then suddenly the velocity increases to unreasonable values.
I increased the resolution of the mesh with unchanged results.
I have this problem generally with icoFoam that U increases until icoFoam crashes with a floating point error.
I understand I am doing something wrong, so if someone could point me in the right direction I would appreciate it.
Thank you.
Bylund is offline   Reply With Quote
Old   November 20, 2011, 18:38
I think I found the reason for this problem.
After decreasing deltaT from 0.1 to 0.005 it seems to work good.
Could be useful for anyone else who stumbles upon this problem.
Mechanical Engineer
Old   November 20, 2011, 20:48
Alberto Passalacqua
Hint: Check that the Courant number is < 1. If you need large time-steps, use pimpleFoam.
Alberto Passalacqua
crash, icofoam, openfoam
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 13:58
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 05:35
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
Velocity output error after scaling mesh in icoFoam philippose OpenFOAM Running, Solving & CFD 4 October 9, 2006 16:51
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
