-   -   Get output of time derivative (http://www.cfd-online.com/Forums/openfoam-solving/94553-get-output-time-derivative.html)
nandiganavishal November 18, 2011 17:49
Dear Foamers,
I would like to know, if we can get the time derivative of a variable as the output. For instance, if I am solving the transient Navier Stokes, is it possible to get the acceleration (du/dt) too at every time step as an output.
Kindly let me know.
Regards
Vishal Nandigana
alberto November 20, 2011 21:47
Use fvc::ddt(yourField) to store it in a volField of the same type of your field. Setting the IOobject to AUTO_WRITE will have the time derivative stored.
nandiganavishal November 21, 2011 12:45
Thanks Alberto. It worked well.
Andrea_85 March 14, 2012 13:53
how can i get the same in a postprocessing? If i use this code:
read U
read rho
volVectorField ddt
IOobject
"ddt",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
fvc::ddt(rho,U)
ddt.write()
it returns always zero.
best
andrea
alberto March 14, 2012 14:04
Originally Posted by Andrea_85 (Post 349471)
read U
read rho
volVectorField ddt
IOobject
"ddt",
runTime.timeName(),
mesh,
IOobject::NO_READ,
fvc::ddt(rho,U)
ddt.write()
best
andrea
If you only declared the field in createFields.H, it is normal. You have to
a) declare the field as you did in createFields.H
b) add the line
ddt == fvc::ddt(rho,U);
at the end of pEqn.H, so you have the corrected velocity. You do not need the .write() call if you define the field with AUTO_WRITE in the global scope.
Best,
