DRAG coefficient prediction
Old   November 23, 2011, 19:42
Default DRAG coefficient prediction
thinkagain is on a distinguished road
Hello
I'm trying to determinate the polars for an airfoil 2D and I created a test case with a NACA 0012 on openFOAM 2.0.1
I obtained very good value for lift and moment coefficient, while the drag coefficient is very strange related with the ABBOTT results
I attached the compare between my results and the ABBOTT
- the fvScheme and fvSolution are the same of the airfoil 2D tutorials
- the boundary conditions are:
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (69.62 0 7.32);
boundaryField
inlet
type freestream;
freestreamValue uniform (69.62 0 7.32);
outlet
type freestream;
body
type fixedValue;
value uniform (0 0 0);
leftAndright
type empty;
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type freestreamPressure;
outlet
body
type zeroGradient;
leftAndright
type empty;
version 2.0;
format ascii;
object nut;
dimensions [0 2 -1 0 0 0 0];
internalField uniform 1.8766e-05;
boundaryField
inlet
type freestream;
freestreamValue uniform 1.8766e-05;
outlet
type freestream;
body
type nutUSpaldingWallFunction;
value uniform 0;
leftAndright
type empty;
version 2.0;
format ascii;
object nuTilda;
internalField uniform 7.25e-05;
boundaryField
inlet
type freestream;
freestreamValue uniform 7.25e-05;
outlet
type freestream;
body
type fixedValue;
value uniform 0;
leftAndright
type empty;
rho = 1.225 kg/m^3
nu = 1.45e-05 m^2/s^2
- I used the Spalart-Allmaras turbulence model
the yplus is near 90, that would be good, becuase is in the logaritmic BL
I attached my mesh
There is anyone that could help and explain why I obtained those results
Last questions:
in the forceCoeff.C file if these
vector totForce = fm.first().first() + fm.first().second();
vector totMoment = fm.second().first() + fm.second().second();
scalar liftForce = totForce & liftDir_;
scalar dragForce = totForce & dragDir_;
scalar sideForce = totForce & sfDir_;
scalar pitchMoment = totMoment & pitchAxis_;
scalar Cl = liftForce/(Aref_*pDyn);
scalar Cd = dragForce/(Aref_*pDyn);
scalar Cy = sideForce/(Aref_*pDyn);
scalar Cm = pitchMoment/(Aref_*lRef_*pDyn);
what is fm.first() and the other term to calculate the totForce?
Thank you for every useful answers! I need help!
Andrea
thinkagain is offline   Reply With Quote
Drag Coefficient Convergence Problem John FLUENT 18 June 24, 2023 09:22
drag coefficient in ansys fluent 12.0 krishna FLUENT 19 April 12, 2018 00:49
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Drag coefficient for parcels in dieselFoam sebastian_vogl OpenFOAM Running, Solving & CFD 5 December 31, 2008 12:19
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
