Bananas!!! error in GGI and GAMG
Old   November 14, 2011, 04:33
Default Bananas!!! error in GGI and GAMG
waku2005 is on a distinguished road
Dear all,
I simulated 3-D vertical wind turbine rotors using pimpleDyMFoam with GGI on OF1.6-ext (latest Git ver.).
Some cases worked fine but another case failed with FATAL error message like below at p iteration stage which uses GAMG solver.
In this error message, what "bananas!!!" means ?
Thanks in advance,
waku
---- error -----
[waku@ensis11 pimpleDyMFoam_VAWT2_NACA0018]$ pimpleDyMFoam
[snip: FOAM headers]
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh mixerGgiFvMesh
Initializing the GGI interpolator between master/shadow patches: statorInterface/rotorInterface
void mixerGgiFvMesh::addZonesAndModifiers() : Zones and modifiers already present. Skipping.
Mixer mesh:
origin: (0 0 1)
axis : (0 0 1)
rpm : -191
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
alphaK1 0.85034;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.85616;
gamma1 0.5532;
gamma2 0.4403;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
c1 10;
Reading field rAU if present
Starting time loop
Courant Number mean: 0 max: 0.0365714 velocity magnitude: 5
Time = 5e-05
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 7.55501e-06, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 9.75065e-08, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 1.70441e-06, No Iterations 1
--> FOAM FATAL ERROR:
Bananas!!!
From function ggiGAMGInterfaceField::updateInterfaceMatrix
in file matrices/lduMatrix/solvers/GAMG/interfaceFields/ggiGAMGInterfaceField/ggiGAMGInterfaceField.C at line 113.
FOAM aborting
waku2005 is offline   Reply With Quote
Old   November 14, 2011, 05:40
Pawel Sosnowski
psosnows is on a distinguished road
This should clear the problem
http://openfoamwiki.net/index.php/Op...de/Use_bananas
Good luck!
psosnows is offline   Reply With Quote
Old   November 14, 2011, 06:46
akidess's Avatar
Anton Kidess
Pawel, I had the same though reading the thread title, but this error is unrelated in my opinion.
Edit:
The offending piece of code is:
110     // New treatment.  HJ, 26/Jun/2011
111     if (zonePnf.size() != faceCells.size())
112     {
113         FatalErrorIn("ggiGAMGInterfaceField::updateInterfaceMatrix")
114             << "Bananas!!!"
115             << abort(FatalError);
116     }
Old   November 14, 2011, 09:21
Thanks Anton and Pawel
I know the banana method mentioned by Pawel.
Anton's comment gives me useful suggestions.
I'll check my mesh.
Best regards
waku
Old   November 15, 2011, 03:50
Thumbs up
Dear all,
I checked my mesh but no error was found in my data with checkMesh command,
however, I found zonePf.size() had non zero value even faceCell.size() was zero
during p calculation stage of the below if statement.
Does the way of GGI come to include something new after jun/2011 update ?
Any suggestions are highly welcomed.
waku
112 {
113 FatalErrorIn("ggiGAMGInterfaceField::updateInterfa ceMatrix")
114 << "Bananas!!!"
116 }
Old   November 17, 2011, 15:01
Sinisa Majer
smajer is on a distinguished road
Hi waku2005,
I've had a same problem several weeks ago, and I solved it by replacing GAMG solver for p with PCG. After few iterations I replaced it again with GAMG and after that everything worked just fine. I cannot explain the reason for this behavior, but it worked for me.
Regards,
S
smajer is offline   Reply With Quote
Old   November 17, 2011, 17:41
Dear Sinisa
Thanks a lot !
I've just replace GAMG to PCG solver for a workaround.
I'll do the same with your suggestion.
Regards
waku
Old   November 21, 2011, 22:22
Dear Sinisa
Sorry to my late response.
I've just test PCG solver for several time steps from startTime,
and then changed to the pressure solver to GAMG but failed to continue my run with the same "Bananas!" error.
Regards
waku
Old   November 22, 2011, 05:47
Sinisa Majer
Sorry,but I have no idea where is the problem. This worked for me and I didn't try to find out why.
Perhaps you should iterate more time steps with PCG (but this looks like a 'blind man's attempt').
S
Old   November 22, 2011, 06:26
Thanks a lot!
I'll continue to find where is the problem.
waku
at 24/11/2011
I've just found that the parallel run with GAMG solver works !
GGI in OpenFOAM-1.5-dev philippose OpenFOAM Running, Solving & CFD 14 November 13, 2011 14:55
Performance of GGI case in parallel hannes OpenFOAM Running, Solving & CFD 26 August 3, 2011 03:07
Increasing Iter. number of GAMG in pimpleDyMFoam with GGI waku2005 OpenFOAM 0 July 3, 2011 20:21
GAMG does not work using the regionCouple-BC herbert OpenFOAM Running, Solving & CFD 1 December 17, 2009 10:01
