Home > Forums > OpenFOAM Running, Solving & CFD
groovyBC for pressureInlet
Old   November 23, 2011, 09:39
Default groovyBC for pressureInlet
Nico A. is on a distinguished road
I got a two phase flow in a plate with two inlets. The second inlet should open at a specified time like:
inlet
 type            totalPressure;
        p0              uniform 100000;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           uniform 0;
 inlet2
 type                 groovyBC;
 valueExpression  "(time()<t0) ? 0 : 1*(pinlet)";           //zeroGradient for time()<t0 (wall), constant value for time()>t0 (pressureInlet)
 variables            "t0=0.1;pinlet@inlet=p;p=100000;";
 value uniform      100000;
 outlet
  type fixedValue;
  value uniform 0.000000;
 outlet2
  type fixedValue;
 wall
  type zeroGradient;
 frontback
  type empty;
This case works fine. Now I want to open inlet2 depending on a field value like pressure, alpha volume fraction etc. Is that possible in some way? Thanks for any advice.
Kind regards, Nico
Nico A. is offline   Reply With Quote
Old   November 23, 2011, 14:59
Assistant Moderator
Bernhard Gschaider
inlet
 type            totalPressure;
        p0              uniform 100000;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           uniform 0;
 inlet2
 type                 groovyBC;
 outlet
  type fixedValue;
 outlet2
  type fixedValue;
 wall
  type zeroGradient;
 frontback
  type empty;
Kind regards, Nico
a) from the syntax I see that you're using oldSchool-standalone-groovyBC. Just a remark. If it is sufficient for you, fine
b) I think your comment with inlet2 is incorrect. To get that kind of behaviour you should manipulate fractionExpression
c) I don't see the problem with dependence of fields. Instead of the time-condition "time()<t0" write something like "max(pInlet)>pThres" and off you go (to have a "valve" that stays open once the condition is reached - even if the pressure drops afterwards - you'll need the stored variables in the swak-veriosn of groovBC)
Old   November 24, 2011, 09:53
Hello Bernhard,
at first, thank you for your reply. Sorry, I posted the wrong code, I actually used that for inlet2, like you already said:
inlet2
{      type groovyBC;
        valueExpression "1*(pinlet)";
        fractionExpression "(time()<t0) ? 0 : 1";
        timelines       ( )
re a) up to now the oldSchool-groovyBC was sufficient for me, but for the next tasks I am not sure.
re c) the problem is that I can only adress the whole field, is that right? I need to extract a specific value of the field, for example a face value at the inlet patch.
Old   November 24, 2011, 18:07
Assistant Moderator
Bernhard Gschaider
Hello Bernhard,
inlet2
{      type groovyBC;
        timelines       ( )
Just one face should represent the whole inlet instead of (for instance) the average of all the faces on the patch? That's not really what groovyBC was built for, but something like (untested so there may be syntactic problems may be there):
"targetPos=vector(1,2,3);dist=mag(targetPos-pos());minDist=min(dist);pTemp=(dist==minDist) ? p : -1;pUsed=max(pTemp)"
should work.
Hold on.
That won't work exactly like this because as soon as a remote variable is used it is boiled down to a single value. But what should work is
"pUsed@inlet2= ...."
The right hand side you get by substituting the other variables in the expression of the above "recipie". Will be a bit larger, but I guess you get the idea
PS: the "1*(pinlet)" above is necessary? Hopefully not anymore in the swak-Variant of groovy
Thread Tools
Trackbacks are On
groovyBC and funkySetFields married and got a kid named swak4Foam gschaider OpenFOAM 164 January 13, 2015 03:52
GroovyBC problem in the defining inlet velocity iampolaris OpenFOAM Running, Solving & CFD 7 October 18, 2014 09:25
GroovyBC for 2D wave flume! Hisham OpenFOAM Running, Solving & CFD 13 January 20, 2012 06:04
groovyBC and Eqn.setReference() benk OpenFOAM 3 June 2, 2011 08:49
Wall heat transfer using groovyBC (XiFoam solver) usergk OpenFOAM 7 February 4, 2011 14:36
