November 24, 2011, 11:13 |
Parallel rerun in cluster
Dear Foamers.
I have same problem with rerun my case after cluster turn off and again turn on.For example, in first day I put my case in queue calculation, I use the following script: Code:
#PBS -l walltime=24:00:00,nodes=4:ppn=8 cd ~/OpenFOAM/Andrey-2.0.1/run/SWkw mpirun -np 32 -machinefile $PBS_NODEFILE rhoCentralFoam -parallel | tee -a log.std 1) Case is in queue but don't calculation.Use time in qstat = constant 00:00:00. 2) Case is not in queue, and in working directory I have file .e , .o created at the moment of switching-off cluster. in controlDict starttime set to latestTime. What probably to make,after cluster turn on,that openfoam continued to calculation? Thanks. |
November 25, 2011, 02:40 |
Anton Kidess
Rep Power: 29 |
Do you have superuser rights on the cluster?
November 25, 2011, 13:38 |
No, I have not root rights,but I can say superuser on this cluster that it is possible to make.
November 27, 2011, 06:27 |
Anton Kidess
Rep Power: 29 |
First, you should ask the administrator to not turn off the cluster so that your jobs can finish over night. If that's absolutely not possible, you'll have to ask him to set up an init.d script to restart your jobs on reboot.
November 27, 2011, 07:16 |
Unfortunately,not turn off the cluster is impossible.
Could you tell as to adjust this init.d script? |
Script to Run Parallel Jobs in Rocks Cluster | asaha | OpenFOAM Running, Solving & CFD | 12 | July 4, 2012 22:51 |
Parallel Solving with HPC Cluster? | bah | OpenFOAM Running, Solving & CFD | 8 | October 13, 2011 03:08 |
Parallel cluster solving with OpenFoam? P2P Cluster? | hornig | OpenFOAM Programming & Development | 8 | December 5, 2010 16:06 |
Unable to run OF in parallel on a multiple-node cluster | quartzian | OpenFOAM | 3 | November 24, 2009 13:37 |
Help: how to realize UDF on parallel cluster? | Haoyin | FLUENT | 1 | August 6, 2007 13:53 |
