November 30, 2011, 11:12 |
DecomposePar
Evangelos
Rep Power: 14 |
hello i want to run my case in parallel my computer has 2 processors
so from decompose picture am i right ? when i write "mpirun -npsimpleFoam -parrallel >log& i have a problem (mpirun picture) mpi run was unable to launch the specified application... executable :-p why p is not executable where am i wrong ? |
November 30, 2011, 11:18 |
Bernhard
Rep Power: 21 |
Don't forget the space between -np and simpleFoam!
November 30, 2011, 16:30 |
Evangelos
Rep Power: 14 |
ok! i fix the first problem now i have another one
can you help me ? |
November 30, 2011, 17:57 |
Michael Ahlmann
Rep Power: 16 |
The correct command is the following:
mpirun -np 2 simpleFoam -parallel >> log & mpirun is the name of the parallel message passing interface launch script. -np specifies number of processors, in your case 2. Best of luck, -Michael |
December 1, 2011, 15:24 |
Evangelos
Rep Power: 14 |
hello Foamers
i am a little bit confused check my picture please can you tell me what i've done ? [1] - Done mpirun.... [2] + Done mpirun.... why two mpirun commands? |
decomposePar gives errors | of_user_ | OpenFOAM | 1 | July 4, 2011 05:27 |
checkMesh and decomposePar crashes with salome IDEAS mesh | pajofego | OpenFOAM | 0 | June 23, 2011 08:43 |
decomposePar: can use this decomposition method only for the whole mesh | aloeven | OpenFOAM Bugs | 0 | March 16, 2011 10:15 |
Strange behaviour 1.6 decomposePar vs 1.7 decomposePar | BlueyTheDog | OpenFOAM | 7 | January 16, 2011 18:12 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
