Home > Forums > OpenFOAM Running, Solving & CFD
Compilation of the Solver of mydieselFoam
Old   November 30, 2011, 23:53
Default Compilation of the Solver of mydieselFoam
Pang
kmpang is on a distinguished road
Hi Foamers!
I'm starting to learn OpenFOAM with the dieselFoam Tutorial. At the final part, I compiled the library but failed to compile the solver. Following is the message at the terminal.
Making dependency list for source file dieselFoam.C
SOURCE=dieselFoam.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam201/src/../applications/solvers/combustion/dieselEngineFoam -I/opt/openfoam201/src/finiteVolume/lnInclude -I/opt/openfoam201/src/turbulenceModels/compressible/turbulenceModel -I/opt/openfoam201/src/lagrangian/basic/lnInclude -I/opt/openfoam201/src/meshTools/lnInclude -I/home/karmun/OpenFOAM/karmun-2.0.1/src/lagrangian/mydieselSpray/lnInclude -I/opt/openfoam201/src/thermophysicalModels/properties/liquidProperties/lnInclude -I/opt/openfoam201/src/thermophysicalModels/properties/liquidMixtureProperties/lnInclude -I/opt/openfoam201/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam201/src/thermophysicalModels/thermophysicalFunctions/lnInclude -I/opt/openfoam201/src/thermophysicalModels/reactionThermo/lnInclude -I/opt/openfoam201/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam201/src/thermophysicalModels/laminarFlameSpeed/lnInclude -I/opt/openfoam201/src/../applications/solvers/reactionThermo/XiFoam -I/opt/openfoam201/src/thermophysicalModels/chemistryModel/lnInclude -I/opt/openfoam201/src/ODE/lnInclude -IlnInclude -I. -I/opt/openfoam201/src/OpenFOAM/lnInclude -I/opt/openfoam201/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/dieselFoam.o
g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam201/src/../applications/solvers/combustion/dieselEngineFoam -I/opt/openfoam201/src/finiteVolume/lnInclude -I/opt/openfoam201/src/turbulenceModels/compressible/turbulenceModel -I/opt/openfoam201/src/lagrangian/basic/lnInclude -I/opt/openfoam201/src/meshTools/lnInclude -I/home/karmun/OpenFOAM/karmun-2.0.1/src/lagrangian/mydieselSpray/lnInclude -I/opt/openfoam201/src/thermophysicalModels/properties/liquidProperties/lnInclude -I/opt/openfoam201/src/thermophysicalModels/properties/liquidMixtureProperties/lnInclude -I/opt/openfoam201/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam201/src/thermophysicalModels/thermophysicalFunctions/lnInclude -I/opt/openfoam201/src/thermophysicalModels/reactionThermo/lnInclude -I/opt/openfoam201/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam201/src/thermophysicalModels/laminarFlameSpeed/lnInclude -I/opt/openfoam201/src/../applications/solvers/reactionThermo/XiFoam -I/opt/openfoam201/src/thermophysicalModels/chemistryModel/lnInclude -I/opt/openfoam201/src/ODE/lnInclude -IlnInclude -I. -I/opt/openfoam201/src/OpenFOAM/lnInclude -I/opt/openfoam201/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed Make/linuxGccDPOpt/dieselFoam.o -L/opt/openfoam201/platforms/linuxGccDPOpt/lib \
-lcompressibleTurbulenceModel -lcompressibleRASModels -lcompressibleLESModels -lreactionThermophysicalModels -llagrangian -lmeshTools -ldieselSpray -lliquidProperties -lliquidMixtureProperties -lthermophysicalFunctions -lspecie -lbasicThermophysicalModels -llaminarFlameSpeedModels -lchemistryModel -lODE -ldistributionModels -lfiniteVolume -lpdf -L/home/karmun/OpenFOAM/karmun-2.0.1/lib/linuxGccDPOpt -lmydieselSpray -lOpenFOAM -ldl -lm -o /home/karmun/OpenFOAM/karmun-2.0.1/platforms/linuxGccDPOpt/bin/mydieselFoam
/usr/bin/ld: cannot find -lpdf
/usr/bin/ld: cannot find -lmydieselSpray
I followed the steps taught in the tutorial by adding
-lpdf \
-L$(WM_PROJECT_USER_DIR)/lib/$(WM_OPTIONS) \
-lmydieselSpray
in the /mydieselSpray/Make/options file.
But when I searched around the OpenFOAM directories and sub-directories, I couldn't find libraries of pdf and mydieselSpray. Did I miss any important step? Can anyone of you kindly advise me?
For your information, I'm using OpenFOAM 2.0.1 and I installed it at /opt.
Many thanks in advance.
Best regards,
Kar.
kmpang is offline   Reply With Quote
Old   December 3, 2011, 22:28
Pang
Oopss! I think I found the solution. Apparently lpdf doesn't exist in OpenFOAM 2.0.1 but only in those older-version OpenFOAM.
Thread Tools
Trackbacks are On
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
A New Solver for Supersonic Combustion nakul OpenFOAM 6 March 30, 2014 03:00
A New Solver for Supersonic Combustion nakul OpenFOAM Announcements from Other Sources 18 February 19, 2013 08:48
Development of a Low mach PISO solver nishant_hull OpenFOAM Programming & Development 0 August 25, 2009 12:48
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
