-   -   heat flux on boussinesq (http://www.cfd-online.com/Forums/openfoam-solving/95254-heat-flux-boussinesq.html)
Andrev December 11, 2011 13:18
Dear Foam's,
Im trying to set heat flux as a boundary condition of my buoyantboussinesqSimpleFoam case. But my solution is too dependent of the mesh resolution, as I refine my mesh the final temperature of the fluid descreases each time more.
Qflux = k*(gradT)
gradT = qflux/k ; k=0,17 , Qflux = 10000
so Im setting in the T file :
fixedWalls
type fixedGradient;
gradient uniform 58823;
Can anyone tell me what am I doing wrong ?
Thanks for the attention.
Andrev December 11, 2011 13:19
(Im considering K constant...)
romant December 12, 2011 03:27
does the temperature become less than the temperature that you calculate with the a simple heat balance?
what kind of turbulence modeling do you use?
Andrev December 12, 2011 07:05
Yes, it become less then that i calculated with simple heat balance as I refine mesh.
Its a laminar flow.
romant December 12, 2011 07:11
Its a laminar flow.
what kind of geometry are we talking about, what is your yPlus of your first cell and what kind of fluid do u treat (Pr = 1, Pr > 1 or Pr < 1)
Andrev December 12, 2011 07:23
Its a simple rectangular channel section flow with constant heatflux on the fixed walls (4 walls), ethanol is the fluid (Pr ~ 16.5).
