Home > Forums > OpenFOAM Running, Solving & CFD
[OpenFOAM-2.1.0] kklOmega RAS Turbulence Model (low Re)
Like Tree8Likes
Old   June 16, 2014, 09:38
M. Montero
be_inspired is on a distinguished road
Joe ferrari,
In your thesis, you stated that nut at wall should be zeroGradient. I also noticed that internal field is initialized to "zero".
I am having a similar problem like you ( but using SimpleFoam) but I can not solve it changin nut to fixedValue.
kl at the wake of the airfoil is very high and at the end, the solution diverges.
be_inspired is offline   Reply With Quote
Old   July 17, 2014, 04:20
Ye Zhang
kiddmax is on a distinguished road
Dear Mojtab,
Do you set the omega boundary condition at the wall the same as the komega SST turbulence model? I also made this mistake. Change it to zeroGradient, and should be fine.
Best regards
Ye
kiddmax is offline   Reply With Quote
Old   July 17, 2014, 16:51
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Originally Posted by kiddmax View Post
Dear Mojtab,
Best regards
Ye
Dear Ye,
Yes, that was the problem.
Thank you for your kind response.
With all the best wishes.
Mojtaba
Learn OpenFOAM in Persian for free, And ask your questions here.
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   September 11, 2014, 13:27
Default which airfoil
  #64
Alberto
malv83 is on a distinguished road
Originally Posted by be_inspired View Post
Joe ferrari,
Hi, I was wondering if you can provide me some more information on the airfoil test case you were running referred in this post. What was the geometry?, Inlet conditions.
Thanks in advanced
malv83 is offline   Reply With Quote
Old   June 17, 2016, 14:39
Default New model
  #65
Alberto
After 8 years, there is a new version (or new model) of the k-kl-omega model.
There are a few problems with the k-kl-omega model in the farfield. One of them is the growth of Laminar Kinetic energy when separation occurs. Lopez and Walters have a paper (have not been published yet) correcting this issue:
Maurin Lopez. D. K. Walters. “A recommended correction to the k-kl-omega transition sensitive eddy-viscosity model”. Journal of Fluid Engineering.
This correction has to be made to the 2008 k-kl-omega model from now on.
Now, Lopez and Walters also developed a new transitional model (k-omega-v2) as an alternative to the k-kl-omega one. This new model has more capabilities (it is more reliable) than the k-kl-omega model, especially in the farfield computations. Fortunately the paper for this new model is already publish.
Maurin Lopez. D. K. Walters. “Prediction of transitional and fully turbulent free shear flows using an alternative to the laminar kinetic energy approach”. Journal of Turbulence, Vol 17, Iss. 3, 2016.
If you see the papers, you will immediately see how the k-kl-omega model is not good for free shear flows, and how the new model corrects all those issues. From now on, k-kl-omega users have to start using the new k-omega-v2 model.
Hope this helps
Thread Tools
Trackbacks are On
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Turbulence model for low Reynolds number flow? Nokadu Main CFD Forum 3 May 26, 2013 11:42
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
turbulence model equation Andy Chen FLOW-3D 4 January 1, 2010 22:45
build your own turbulence model with buoyancy Thomas Baumann OpenFOAM 11 November 23, 2009 09:53
