December 24, 2011, 15:38 |
Total pressure BC with simple foam
duri
I am trying out fluent's MRF tutorial in MRFSimpleFoam. For inlet BC I used total pressure bc where i could preserve my inlet total pressure. While running it shown some error that volScalarField rho not found. So, i removed rho and psi field from total pressure BC.
Now solver is starting the iteration but pressure and velocity became completely unbounded. My BC's are, inlet : total pressure fixed to 200 velocity zeroGradient outlet : pressure fixedValue to 0 velocity zeroGradient Please help me in setting up inlet bc. One more doubt, do i need to include surface names that rotate along with rotating zone in nonrotatingpatch () in MRFZone file. Thanks |
March 20, 2012, 08:05 |
Attesz
did you find answer for your problem? I want to use the same boundary conditions like you, was it stable? Thanks |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 10:08 |
Total pressure in CFX | famarcfd | CFX | 0 | June 17, 2011 10:33 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Total pressure in a laval nozzle | Sohail Ahmed | FLUENT | 0 | May 19, 2004 05:28 |
