Artex85 |
December 29, 2011 09:50 |
Hello anon_a!
Thanks for your quick reply, here is the log file:
Exec : icoFoam
Date : Dec 29 2011
Time : 13:36:10
Host : ubuntu
PID : 5099
Case : /home/ubuntu/OpenFOAM/ubuntu-1.5-dev/run/duese_3_tet_icofoam
nProcs : 1
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 0.02
Courant Number mean: 0 max: 0 velocity magnitude: 0
PBiCG: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
PBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
PBiCG: Solving for Uz, Initial residual = 1, Final residual = 7.92461e-06, No Iterations 42
PCG: Solving for p, Initial residual = 1, Final residual = 8.51221e-07, No Iterations 484
PCG: Solving for p, Initial residual = 0.102054, Final residual = 9.82929e-07, No Iterations 459
time step continuity errors : sum local = 1.31195e-07, global = -3.07613e-10, cumulative = -3.07613e-10
PCG: Solving for p, Initial residual = 0.054511, Final residual = 8.62196e-07, No Iterations 472
PCG: Solving for p, Initial residual = 0.466713, Final residual = 8.97311e-07, No Iterations 467
time step continuity errors : sum local = 2.20975e-08, global = 1.92533e-11, cumulative = -2.88359e-10
ExecutionTime = 16.7 s ClockTime = 17 s
Time = 0.04
Courant Number mean: 0.00506339 max: 3.82497 velocity magnitude: 0.0552267
PBiCG: Solving for Ux, Initial residual = 0.748645, Final residual = 8.16663e-06, No Iterations 31
PBiCG: Solving for Uy, Initial residual = 0.771322, Final residual = 9.49122e-06, No Iterations 34
PBiCG: Solving for Uz, Initial residual = 0.6344, Final residual = 8.92808e-06, No Iterations 39
PCG: Solving for p, Initial residual = 0.602528, Final residual = 8.92601e-07, No Iterations 488
PCG: Solving for p, Initial residual = 0.110327, Final residual = 8.24463e-07, No Iterations 459
time step continuity errors : sum local = 5.43346e-07, global = 8.05496e-10, cumulative = 5.17137e-10
PCG: Solving for p, Initial residual = 0.0449353, Final residual = 8.84106e-07, No Iterations 470
PCG: Solving for p, Initial residual = 0.461692, Final residual = 8.98988e-07, No Iterations 466
time step continuity errors : sum local = 1.19582e-07, global = -1.29784e-10, cumulative = 3.87353e-10
ExecutionTime = 34.37 s ClockTime = 34 s
Time = 0.06
Courant Number mean: 0.0263615 max: 13.485 velocity magnitude: 0.19658
PBiCG: Solving for Ux, Initial residual = 0.764436, Final residual = 9.74761e-06, No Iterations 34
PBiCG: Solving for Uy, Initial residual = 0.778582, Final residual = 9.481e-06, No Iterations 37
PBiCG: Solving for Uz, Initial residual = 0.645542, Final residual = 7.43444e-06, No Iterations 40
PCG: Solving for p, Initial residual = 0.60749, Final residual = 8.64835e-07, No Iterations 488
PCG: Solving for p, Initial residual = 0.129048, Final residual = 8.77098e-07, No Iterations 457
time step continuity errors : sum local = 3.23187e-06, global = -1.31075e-09, cumulative = -9.234e-10
PCG: Solving for p, Initial residual = 0.0464013, Final residual = 9.64245e-07, No Iterations 468
PCG: Solving for p, Initial residual = 0.490751, Final residual = 9.75743e-07, No Iterations 464
time step continuity errors : sum local = 8.02591e-07, global = 2.05433e-09, cumulative = 1.13093e-09
ExecutionTime = 52.24 s ClockTime = 52 s
Time = 0.08
Courant Number mean: 0.17455 max: 55.7621 velocity magnitude: 0.812884
PBiCG: Solving for Ux, Initial residual = 0.775338, Final residual = 9.18494e-06, No Iterations 36
PBiCG: Solving for Uy, Initial residual = 0.780003, Final residual = 8.83473e-06, No Iterations 38
PBiCG: Solving for Uz, Initial residual = 0.649195, Final residual = 7.62692e-06, No Iterations 40
PCG: Solving for p, Initial residual = 0.661197, Final residual = 9.82732e-07, No Iterations 479
PCG: Solving for p, Initial residual = 0.163826, Final residual = 9.35047e-07, No Iterations 442
time step continuity errors : sum local = 2.31072e-05, global = 1.43139e-07, cumulative = 1.4427e-07
PCG: Solving for p, Initial residual = 0.0544162, Final residual = 9.93518e-07, No Iterations 465
PCG: Solving for p, Initial residual = 0.535228, Final residual = 9.42873e-07, No Iterations 448
time step continuity errors : sum local = 6.10979e-06, global = -3.08389e-08, cumulative = 1.13431e-07
ExecutionTime = 69.79 s ClockTime = 70 s
Time = 0.1
Courant Number mean: 1.52184 max: 251.177 velocity magnitude: 3.66159
PBiCG: Solving for Ux, Initial residual = 0.785002, Final residual = 7.78131e-06, No Iterations 37
PBiCG: Solving for Uy, Initial residual = 0.775493, Final residual = 7.00292e-06, No Iterations 38
PBiCG: Solving for Uz, Initial residual = 0.653513, Final residual = 7.65689e-06, No Iterations 39
PCG: Solving for p, Initial residual = 0.73722, Final residual = 8.38555e-07, No Iterations 487
PCG: Solving for p, Initial residual = 0.210158, Final residual = 8.81948e-07, No Iterations 458
time step continuity errors : sum local = 0.000179504, global = 6.47978e-09, cumulative = 1.19911e-07
PCG: Solving for p, Initial residual = 0.0671591, Final residual = 9.26519e-07, No Iterations 469
PCG: Solving for p, Initial residual = 0.577796, Final residual = 8.43418e-07, No Iterations 464
time step continuity errors : sum local = 5.39014e-05, global = 3.38347e-08, cumulative = 1.53746e-07
ExecutionTime = 88.14 s ClockTime = 88 s
Time = 0.12
Courant Number mean: 15.771 max: 1213.58 velocity magnitude: 17.2683
PBiCG: Solving for Ux, Initial residual = 0.791247, Final residual = 4.09263e-06, No Iterations 47
PBiCG: Solving for Uy, Initial residual = 0.768959, Final residual = 1.95723e-06, No Iterations 53
PBiCG: Solving for Uz, Initial residual = 0.660241, Final residual = 7.56799e-06, No Iterations 53
PCG: Solving for p, Initial residual = 0.809628, Final residual = 8.35623e-07, No Iterations 481
PCG: Solving for p, Initial residual = 0.270383, Final residual = 9.78329e-07, No Iterations 459
time step continuity errors : sum local = 0.00202547, global = 2.30268e-06, cumulative = 2.45642e-06
PCG: Solving for p, Initial residual = 0.0840898, Final residual = 8.179e-07, No Iterations 468
PCG: Solving for p, Initial residual = 0.611435, Final residual = 9.48164e-07, No Iterations 464
time step continuity errors : sum local = 0.000754444, global = -2.30185e-07, cumulative = 2.22624e-06
ExecutionTime = 107.21 s ClockTime = 107 s
Time = 0.14
Courant Number mean: 203.818 max: 6315.59 velocity magnitude: 144.106
PBiCG: Solving for Ux, Initial residual = 0.799529, Final residual = 7.23114e-06, No Iterations 118
PBiCG: Solving for Uy, Initial residual = 0.768657, Final residual = 8.52382e-06, No Iterations 119
PBiCG: Solving for Uz, Initial residual = 0.67574, Final residual = 6.44984e-06, No Iterations 123
PCG: Solving for p, Initial residual = 0.644255, Final residual = 9.53304e-07, No Iterations 501
PCG: Solving for p, Initial residual = 0.124882, Final residual = 8.26806e-07, No Iterations 468
time step continuity errors : sum local = 0.0255069, global = -5.32141e-06, cumulative = -3.09518e-06
PCG: Solving for p, Initial residual = 0.0625569, Final residual = 9.64602e-07, No Iterations 485
PCG: Solving for p, Initial residual = 0.476678, Final residual = 9.36606e-07, No Iterations 483
time step continuity errors : sum local = 0.00664253, global = -2.03334e-05, cumulative = -2.34285e-05
ExecutionTime = 134.23 s ClockTime = 134 s
Time = 0.16
Courant Number mean: 1224.81 max: 5.8799e+06 velocity magnitude: 95137.2
PBiCG: Solving for Ux, Initial residual = 0.995393, Final residual = 0.0200732, No Iterations 1000
PBiCG: Solving for Uy, Initial residual = 0.991433, Final residual = 0.307995, No Iterations 1000
PBiCG: Solving for Uz, Initial residual = 0.985122, Final residual = 0.0269352, No Iterations 1000
PCG: Solving for p, Initial residual = 0.929687, Final residual = 11.7345, No Iterations 1000
PCG: Solving for p, Initial residual = 0.794915, Final residual = 2.26295, No Iterations 1000
time step continuity errors : sum local = 3.50337e+06, global = 10532.6, cumulative = 10532.6
PCG: Solving for p, Initial residual = 0.969994, Final residual = 1.9792, No Iterations 1000
PCG: Solving for p, Initial residual = 0.680809, Final residual = 4.05222, No Iterations 1000
time step continuity errors : sum local = 1.599e+09, global = 1.22747e+07, cumulative = 1.22852e+07
ExecutionTime = 238.53 s ClockTime = 239 s
Time = 0.18
Courant Number mean: 9.19732e+08 max: 1.85522e+12 velocity magnitude: 7.06915e+10
PBiCG: Solving for Ux, Initial residual = 0.999745, Final residual = 9.62717, No Iterations 1000
PBiCG: Solving for Uy, Initial residual = 0.999748, Final residual = 10.851, No Iterations 1000
PBiCG: Solving for Uz, Initial residual = 0.999861, Final residual = 2.88039, No Iterations 1000
PCG: Solving for p, Initial residual = 1, Final residual = 196.18, No Iterations 1000
PCG: Solving for p, Initial residual = 0.843622, Final residual = 5.02074, No Iterations 1000
time step continuity errors : sum local = 2.12167e+18, global = 4.6608e+09, cumulative = 4.67308e+09
PCG: Solving for p, Initial residual = 0.922669, Final residual = 2.7607, No Iterations 1000
PCG: Solving for p, Initial residual = 0.873783, Final residual = 3.07253, No Iterations 1000
time step continuity errors : sum local = 3.67336e+20, global = 4.99835e+15, cumulative = 4.99835e+15
ExecutionTime = 341.26 s ClockTime = 341 s
Time = 0.2
Courant Number mean: 2.28604e+20 max: 8.40228e+23 velocity magnitude: 3.89946e+22
PBiCG: Solving for Ux, Initial residual = 0.999885, Final residual = 6.49499, No Iterations 1000
PBiCG: Solving for Uy, Initial residual = 0.999815, Final residual = 3.9282, No Iterations 1000
PBiCG: Solving for Uz, Initial residual = 0.999772, Final residual = 2.70425, No Iterations 1000
PCG: Solving for p, Initial residual = 1, Final residual = 57.7895, No Iterations 1000
PCG: Solving for p, Initial residual = 0.771788, Final residual = 124.919, No Iterations 1000
time step continuity errors : sum local = 4.00756e+33, global = 5.1915e+25, cumulative = 5.1915e+25
PCG: Solving for p, Initial residual = 0.923169, Final residual = 4.28131, No Iterations 1000
PCG: Solving for p, Initial residual = 0.74075, Final residual = 392.082, No Iterations 1000
time step continuity errors : sum local = 1.39632e+38, global = -1.04069e+30, cumulative = -1.04064e+30
ExecutionTime = 446.61 s ClockTime = 447 s
Time = 0.22
Courant Number mean: 6.86548e+37 max: 1.692e+42 velocity magnitude: 6.1894e+40
PBiCG: Solving for Ux, Initial residual = 0.999959, Final residual = 2.91466, No Iterations 1000
PBiCG: Solving for Uy, Initial residual = 0.999976, Final residual = 0.549805, No Iterations 1000
PBiCG: Solving for Uz, Initial residual = 0.99999, Final residual = 0.420483, No Iterations 1000
PCG: Solving for p, Initial residual = 1, Final residual = 248.252, No Iterations 1000
PCG: Solving for p, Initial residual = 0.0273632, Final residual = 0.0501284, No Iterations 1000
time step continuity errors : sum local = 1.22223e+60, global = 1.90958e+44, cumulative = 1.90958e+44
PCG: Solving for p, Initial residual = 0.132324, Final residual = 1.12506, No Iterations 1000
PCG: Solving for p, Initial residual = 0.0522075, Final residual = 0.24675, No Iterations 1000
time step continuity errors : sum local = 1.9022e+63, global = -1.83909e+50, cumulative = -1.83909e+50
ExecutionTime = 551.96 s ClockTime = 552 s
Time = 0.24
Courant Number mean: 1.41686e+63 max: 2.14683e+67 velocity magnitude: 7.26454e+65
PBiCG: Solving for Ux, Initial residual = 0.999941, Final residual = 5.11203, No Iterations 1000
PBiCG: Solving for Uy, Initial residual = 0.99994, Final residual = 0.204469, No Iterations 1000
PBiCG: Solving for Uz, Initial residual = 0.999928, Final residual = 1.03388, No Iterations 1000
PCG: Solving for p, Initial residual = 1, Final residual = 3.266, No Iterations 1000
PCG: Solving for p, Initial residual = 1.9343e-11, Final residual = 1.9343e-11, No Iterations 0
time step continuity errors : sum local = 1.47482e+88, global = -3.62724e+71, cumulative = -3.62724e+71
PCG: Solving for p, Initial residual = 3.87133e-11, Final residual = 3.87133e-11, No Iterations 0
time step continuity errors : sum local = 2.95171e+88, global = -2.1468e+72, cumulative = -2.50952e+72
ExecutionTime = 633.62 s ClockTime = 634 s
Time = 0.26
Courant Number mean: 8.67119e+87 max: 2.38864e+92 velocity magnitude: 8.00775e+90
PBiCG: Solving for Ux, Initial residual = 0.999973, Final residual = 0.645976, No Iterations 1000
PBiCG: Solving for Uy, Initial residual = 0.99999, Final residual = 0.272165, No Iterations 1000
PBiCG: Solving for Uz, Initial residual = 0.999979, Final residual = 0.313018, No Iterations 1000
PCG: Solving for p, Initial residual = 1, Final residual = 11.673, No Iterations 1000
PCG: Solving for p, Initial residual = 2.40327e-11, Final residual = 2.40327e-11, No Iterations 0
time step continuity errors : sum local = 1.46936e+101, global = 1.28168e+98, cumulative = 1.28168e+98
PCG: Solving for p, Initial residual = 7.36934e-11, Final residual = 7.36934e-11, No Iterations 0
time step continuity errors : sum local = 4.5056e+101, global = 1.7056e+98, cumulative = 2.98729e+98
ExecutionTime = 718.06 s ClockTime = 718 s
Time = 0.28
Courant Number mean: 1.45564e+101 max: 9.1374e+104 velocity magnitude: 3.16353e+103
Floating point exception (core dumped)
cheers
