-   -   interDyMFoam - One rigid body, multiple boundaries (http://www.cfd-online.com/Forums/openfoam-solving/96083-interdymfoam-one-rigid-body-multiple-boundaries.html)
mattkram January 11, 2012 18:15
Hi All,
I am working on a problem where I would like to use interDyMFoam for mesh deformation using the sixDoFRigidBodyDisplacement boundary condition for the boundary point displacements, however there is one caveat. There are additional boundaries that I would like to move with the same rigid body motion. I would like to not calculate the forces on these secondary faces. In addition, these other boundaries are of a different type (i.e. not walls). Is this possible without major modifications to the source code? I'm currently using OF2.0.
To clarify, consider a rigid body whose boundary is represented with two separate adjoining boundaries:
-boundary 1 (no-slip wall)
-boundary 2 (pressure inlet)
Is it possible to use interDyMFoam to model the motion of this body where the motion is calculated based on the forces on boundary 1 only but boundary 2 just moves with the same rigid body motion?
Thanks, I'd appreciate all the help I can get.
-Matt
