-   -   How to call ignitionSites in combustionProperties dictionary in a solver? (http://www.cfd-online.com/Forums/openfoam-solving/96110-how-call-ignitionsites-combustionproperties-dictionary-solver.html)
chenhu January 12, 2012 11:40
Does anybody have idea about calling ignitionSites in combustionProperties dictionary in a solver (e.g. XiFoam)?
ignitionSites gives ignition parameters as following,
ignitionSites
{ location ( 0 0.005 0.01 ) ;
diameter 0.0001 ;
start 0 ;
duration 0.0001 ;
strength 1 ; }
Since ignitionSites has a special data structure (maybe it's a list, but I haven't figured out), which is different from a normal dimensionedScalar (it is easy to be called in a solver).
I tried many ways, but they did not work properly:(. One unsuccessful example,
IOdictinary combustionProperties
IOobject
"combustionProperties",
runTime.constant(),
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
PtrList<ignitionSite> ignitionSites
combustionProperties.lookup("ignitionSites")
Does anybody know how to call e.g. the start of ignition time (0) in the solver?
Thanks!
marupio January 12, 2012 12:31
That is a strange format. It is probably a custom object type with its own read / write functions. It looks like a list of dictionaries, actually.
( this is a list );
{ this is a subdictionary }
( {is this a list of dictionaries?} );
If there's no dictionaryList, try PtrList<dictionary>.
chenhu January 13, 2012 04:12
Hello marupio,
As you have guessed:
({this is a list of dictionaries!});
and I tried PtrList<dictionary>, it works:)!
Then the following code is needed for calling the scalar in a list of dictionaries,
scalar start(readScalar(ignitionSites[0].lookup("start"))); // here only the first dictionary in the list is called.
Thanks a lot for the help!
Chen
RCB123456 August 15, 2014 17:57
Hi people
I'm trying star ignition with this code in this site http://openfoamwiki.net/index.php/Contrib_reactingFoam
but i when i start the simulation nohting happens. Can you see if the code are correct and if miss something?
Thanks
