buoyantSimpleFoam
Old   February 22, 2012, 08:20
Default buoyantSimpleFoam
Samuele Z
samiam1000 is on a distinguished road
Dear all,
I am trying to run buoyantSimpleFoam, but I get this error message.
I can not cope with it.
Could you kindly help?
Thanks a lot,
Samuele
pc:~/Documents/case1 # buoyantSimpleFoam
|  \\    /   O peration     | Version:  2.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : 2.0.1-51f1de99a4bc
Exec   : buoyantSimpleFoam
Date   : Feb 22 2012
Time   : 13:00:51
Host   : pc
PID    : 7511
Case   : /root/Documents/case
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading g
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting RAS turbulence model realizableKE
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib64/libc.so.6"
#3  Foam::compressible::RASModels::mutkWallFunctionFvPatchScalarField::calcMut() const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#4  Foam::compressible::RASModels::mutkWallFunctionFvPatchScalarField::updateCoeffs() in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#5  Foam::fvPatchField<double>::evaluate(Foam::UPstream::commsTypes) in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/buoyantSimpleFoam"
#6  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/buoyantSimpleFoam"
#7  Foam::compressible::RASModels::realizableKE::realizableKE(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&, Foam::word const&, Foam::word const&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#8  Foam::compressible::RASModel::adddictionaryConstructorToTable<Foam::compressible::RASModels::realizableKE>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&, Foam::word const&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#9  Foam::compressible::RASModel::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&, Foam::word const&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#11  __libc_start_main in "/lib64/libc.so.6"
#12
Floating point exception
samiam1000 is offline   Reply With Quote
incompressible thermo type (in buoyantSimpleFoam) andrea.pasquali OpenFOAM 8 November 21, 2013 15:10
Error message when using buoyantSimpleFoam almir OpenFOAM 3 June 8, 2011 07:02
buoyantSimpleFoam velocity oszillation 1.6-ext preibie OpenFOAM Running, Solving & CFD 4 May 13, 2011 04:09
Running buoyantSimpleFoam with oodles data as initialisation samulu OpenFOAM 5 November 19, 2009 11:49
BuoyantSimpleFoam amitshah OpenFOAM Running, Solving & CFD 4 June 3, 2009 06:04
