Home > Forums > OpenFOAM Running, Solving & CFD
FOAM Warning on a submarine with simpleFoam
Like Tree3Likes
  • 3 Post By daveatstyacht
Old   January 17, 2012, 21:00
Question FOAM Warning on a submarine with simpleFoam
Thibaut SIMON
thibautsimon1 is on a distinguished road
Hi everyone,
I'm new with OpenFoam and I done a bit of CFD with CFX before.
I doing a quite simple study about a submarine (without appendages) in OF 2.0.
I'm using simpleFoam to solve it and I adapt a case from OF 1.7 to my OF 2.0.
And when I simpleFoam it, I have the same FOAM Warning which arrive all the time:
--> FOAM Warning :
From function linearUpwind(const fvMesh&, const surfaceScalarField& faceFlux, Istream&)
in file interpolation/surfaceInterpolation/schemes/linearUpwind/linearUpwind.H at line 152
Reading "/home/newuser/OpenFOAM/newuser-2.0.1/run/AlexCases/DeepSubA1/system/fvSchemes::divSchemes::div(phi,k)" at line 34
unexpected additional entries in stream.
Only the name of the gradient scheme in the 'gradSchemes' dictionary should be specified.
And here is my fvSchemes file:
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
// upwind 1st order , linear = second
divSchemes
default none;
div(phi,U) Gauss linearUpwindV cellMDLimited Gauss linear 1;
div(phi,k) Gauss linearUpwind cellMDLimited Gauss linear 1;
div(phi,omega) Gauss linearUpwind cellMDLimited Gauss linear 1;
div(phi,epsilon) Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
If someone have an idea on my problem, I would appreciate if you could help me.
Regards,
Thibaut
thibautsimon1 is offline   Reply With Quote
Old   January 24, 2012, 20:43
Dave Gross
daveatstyacht is on a distinguished road
Thibaut,
The style for linearUpwind has changed since 1.7. From the LTSInterFoam wigleyhull tutorial:
gradSchemes
divSchemes
div(rho*phi,U) Gauss linearUpwind grad(U);
//other schemes here...
Note: you can then go on to specify the way grad(U) is calculated as you have done above in gradSchemes. Essentially "grad(U) cellMDLimited Gauss linear 1;" would be what you want in the gradScheme to replicate the use of MD cell limiting.
Hope this helps,
Dave
daveatstyacht is offline   Reply With Quote
Thread Tools
Trackbacks are On
mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 12 December 12, 2011 04:16
BlockMesh FOAM warning gaottino OpenFOAM Native Meshers: blockMesh 7 July 19, 2010 14:11
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Version 15 on Mac OS X gschaider OpenFOAM Installation 120 December 2, 2009 10:23
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
