-   -   Conservative form of Navier Stokes equation. (http://www.cfd-online.com/Forums/openfoam-solving/96427-conservative-form-navier-stokes-equation.html)
balkrishna January 23, 2012 01:43
I wish to modify the pimpleFoam solver for varying density. As a first step, I decided to change the momentum equation to the conservative form. To do so I changed the momentum equation to
    fvVectorMatrix UEqn
    fvm::ddt(rho, U) +
    fvm::div(phi, U)
    - fvm::laplacian(mu, U)
    - fvc::div(mu*dev2(fvc::grad(U)().T()))
here rho is declared as a volScalarField. The pressure equation is coded in the following way :
    Info<<" In the most dreaded pEqn "<<endl;
    volScalarField rUA = 1.0/UEqn.A();
    surfaceScalarField rhorUAf("(rho*(1|A(U)))", fvc::interpolate(rho*rUA));
    U = rUA*UEqn.H();
    phi = fvc::interpolate(rho)*
        (fvc::interpolate(U) & mesh.Sf())
      + fvc::ddtPhiCorr(rUA, rho, U, phi)
    surfaceScalarField buoyancyPhi = -rhorUAf*ghf*fvc::snGrad(rho)*mesh.magSf();
    phi += buoyancyPhi;
    for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
        fvScalarMatrix p_rghEqn
            fvc::ddt(rho) +
          fvc::div(phi)
          - fvm::laplacian(rhorUAf, p_rgh)
        p_rghEqn.solve
            mesh.solver
                p_rgh.select
                        finalIter
                    && corr == nCorr-1
                    && nonOrth == nNonOrthCorr
        if (nonOrth == nNonOrthCorr)
            // Calculate the conservative fluxes
            phi += p_rghEqn.flux();
            // Explicitly relax pressure for momentum corrector
            p_rgh.relax();
            // Correct the momentum source with the pressure gradient flux
            // calculated from the relaxed pressure
            U += rUA*fvc::reconstruct((buoyancyPhi + p_rghEqn.flux())/rhorUAf);
    p = p_rgh + rho*gh;
    DpDt = fvc::DDt(surfaceScalarField("phiU", phi/fvc::interpolate(rho)), p);
As a first test I decided to simulate for a case of non changing density for a pipe flow.My rho is specified in the following manner.
| \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox          |
|  \\    /  O peration    | Version:  1.7.0                                |
|  \\  /    A nd          | Web:      www.OpenFOAM.com                      |
|    \\/    M anipulation  |                                                |
FoamFile
    version    2.0;
    format      ascii;
    class      volScalarField;
    location    "0";
    object      rho;
dimensions      [1 -3 0 0 0 0 0];
internalField  uniform 1000;
boundaryField
    outlet
        type            fixedValue;
        value          uniform 1000;
    inlet
        type            fixedValue;
        value          uniform 1000;
    wall
      type            fixedValue;
      value          uniform 1000;
    frontBack
        type            empty;
0/rho (END)
This gives highly unphysical results as far as the velocity profiles are concerned. Could someone tell me where I might be going wrong in the momentum equation or pressure equation ?
alberto January 24, 2012 12:22
Take a look at rhoPimpleFoam, and for a solver using p_rgh, you could take a look at buoyantPimpleFoam.
Best,
balkrishna January 25, 2012 09:33
Solved.
thanks for d help.
