June 12, 2012, 20:52 |
the interface reconstruction in InterFoam
Y. Cao
Rep Power: 13 |
Hi, everybody,I am studying the source codes of the InterFoam recently, as far as I known, for VOF method,you have to reconstruct the interface between different phases based on the solution of the volume fraction, however, I haven't seen the codes of the interface reconstructing, So could anybody tell me which kind of interface reconstructing method is used in the solver,and its corresponding codes in interFoam. And also I don't understand the transporting equation of volume fraction (alpha) they used in the solver, so could anybody explain it,or show me the exact formulation of alpha?
June 13, 2012, 02:41 |
Anton Kidess
Rep Power: 29 |
See the publicly available PhD thesis's by Henrik Rusche and Edin Berberovic for details on the algorithm.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
June 13, 2012, 02:52 |
Pablo Higuera
Rep Power: 19 |
Hello Young
no interface reconstruction is carried out in interFoam, as the VOF equation is diffusive an artificial compressive term is added. As pointed out by Anton, check those references for full details. Regards |
June 13, 2012, 06:45 |
Y. Cao
Rep Power: 13 |
Thank both of you, I have download these thesis,I will read them.
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
interFoam - stratified flow - problem with shear stress at interface | AnjaMiehe | OpenFOAM Running, Solving & CFD | 8 | June 14, 2010 06:49 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
