Home > Forums > OpenFOAM Running, Solving & CFD
changing solver
Old   January 25, 2012, 13:39
Default changing solver
insta is on a distinguished road
Hi
As a new user Im trying to understand the OpenFoam software
my question is regarding, lets say to the pitzDaily case
This case solver is the simpleFoam solver
I want to solve this case transiently using the pisoFoam solver
Can anyone give me some directions how to perform this task
ThankYou
insta is offline   Reply With Quote
Old   January 26, 2012, 12:52
Mark Beal
msbealo is on a distinguished road
Insta,
Generally if you want to change solvers you would simply merge two tutorials.
To test, find one tutorial that has an interesting problem/geometry and another tutorial which has a solver that you're interested in. Assuming these are sensible choices, you can make a third directory and merge the two tutorials here (simple by copying the files from each case that you need).
Say you want the geometry from one case and the solver from another then Copy the time directory ('0') and possible the blockMeshDict file from one, and the remains of 'constant' and 'system' from the other.
Have a look over the merged case and make sure all the names of patches etc make sense and run it. You might also need to copy and paste the various lines from the ./Runall script files to make it all run nicely.
The first time you run this, it will probably cause an error. You'll just have to start at the beginning of the ./Runall script and figure out where the error are coming from.
If you get stuck ask a question.
Regards,
Mark
Dynamic Fluid Design
www.dynamic-fluid-design.com
msbealo is offline   Reply With Quote
Old   January 27, 2012, 07:52
Default Thank you for the reply
Hi Mark
Thank you for the reply.
Thread Tools
Trackbacks are On
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
A New Solver for Supersonic Combustion nakul OpenFOAM 6 March 30, 2014 03:00
A New Solver for Supersonic Combustion nakul OpenFOAM Announcements from Other Sources 18 February 19, 2013 08:48
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
