-   -   The floating object tutorial (http://www.cfd-online.com/Forums/openfoam-solving/96641-floating-object-tutorial.html)
Leech January 27, 2012 16:59
i am trying to get a case with floating objects running. Therefore i took several looks at the floatingObject tutorial coming with interDyMFoam.
When i run this tutorial single-core it works and finishes. But when i use decomposePar to split the case on 4 cores it crashes at 1,8s case time.
This is reproducible. It happens on my virtual machine hostet by Win7 and also on my pure Kubuntu machine.
OpenFoam in version 2.1.0 64Bit
This is happening no matter which decomposition method i am using. I used scotch and it crashed at 1,8s case time. When i use the decomposeParDict coming with the tutorial (using hierarchical decomposition) it crashes at 2s case time.
What is happening there?
Any suggestions how to get this fixed?
Thank you!
Greets
Leech
Leech January 27, 2012 19:17
I found a workaround for the problem. They wrote: "There is a problem with the decomposition of point fields (i.e. pointDisplacement).Decompose the mesh before copying 0.org to 0 in each processor directory, so the pointDisplacement field is not operated on by the decomposition"
I tried to do it, but interDyMFoam cant run. I am using this script:
#!/bin/sh
cd ${0%/*} || exit 1 # run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
# Set application name
application=`getApplication`
runApplication blockMesh
runApplication topoSet
runApplication subsetMesh -overwrite c0 -patch floatingObject
runApplication decomposePar
cp -rf 0.org ./processor0/0
cp -rf 0.org ./processor1/0
cp -rf 0.org ./processor2/0
cp -rf 0.org ./processor3/0
cp -rf 0.org ./0
runApplication setFields
runApplication foamJob -screen -parallel interDyMFoam
runApplication reconstructPar
# ----------------------------------------------------------------- end-of-file
interFoam says:
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: displacementLaplacian
[0]
[0]
[0] --> FOAM FATAL IO ERROR:
[0] keyword procBoundary0to1 is undefined in dictionary "/home/foammstr/OpenFOAM/foammstr-2.1.0/run/floatingObject/processor0/0/pointDisplacement::boundaryField"
[0]
[0] file: /home/foammstr/OpenFOAM/foammstr-2.1.0/run/floatingObject/processor0/0/pointDisplacement::boundaryField from line 26 to line 42.
[0]
[0] From function dictionary::subDict(const word& keyword) const
[0] in file db/dictionary/dictionary.C at line 461.
[0]
FOAM parallel run exiting
I guess i confused something in the script, the order is incorrect.
Someone can help me with that?
Thanks!
wyldckat January 28, 2012 08:30
Hi Leech,
Add this entry to "0.org/pointDisplacement":
    "procBoundary.*"
        type            processor;
Here's the modified "Allrun" script:
#!/bin/sh
cp -r 0.org 0 > /dev/null 2>&1
for a in `seq 0 3`; do
  cp 0.org/pointDisplacement processor$a/0/
done
runParallel $application 4
Nonetheless, this doesn't fix the problem.
I've tried reducing the Courant limiters in "system/controlDict". I've tried reducing the relaxation factors and tweaking the PIMPLE parameters and ... no dice. I'm in no way an expert at this, but since others have also tried and failed, even with the 1.7.x version, I suggest that this might be categorized as a bug.
I suggest that you try filling another bug report on this subject: http://www.openfoam.com/mantisbt/my_view_page.php
Best regards,
Bruno
Leech January 28, 2012 18:55
Thanks for your work Bruno!
I reported the bug: http://www.openfoam.com/mantisbt/view.php?id=401
wyldckat January 28, 2012 19:52
Hi Leech,
I've noticed your bug report before I saw your post here ;).
I've also tested the complete workaround that was given in OpenFOAM 1.7.x, on 2.1.x, but with no success either.
Nonetheless, the complete adaptation would be:
  • The Allrun script should contain something like this:
    #!/bin/sh
    #cp -r 0.org 0 > /dev/null 2>&1
    #runApplication setFields
    #runApplication $application
    for proc in processor*
    do
      cp -r 0.org $proc/0 > /dev/null 2>&1
    done
    runParallel setFields 4
    #runApplication reconstructPar
  • The remaining fixes to the files at "0.org" are shown here: https://github.com/OpenCFD/OpenFOAM-...97d7b65de5eef1
Best regards,
Bruno
Leech January 29, 2012 18:55
1 Attachment(s)
Hey,
as I am trying to build a case with floating objects i now switched to singlecore as long as there is no fix. I got a different very confusing problem at this point.
I changed the floatingObject tutorial just a little bit (changed the box to a different size and adjusted the water height and the position of the floating box and the mass centre of the box). I even removed the pile of water crashing down, as i later want to make the waves by waves2Foam (or groovyBC).
When i run interDymFoam in singlecore-mode now it crashes immediately after 2-3 steps. I just cant figure out why. My floating case i made also crashes, thats why i thought i try the tutorial as base and change it in little steps. But as i change one little thing it crashes.
Maybe someone wants to take a look at it, i will attach it. For any tips thank you sooo much!
I am getting hard angry is i am trying to get this floating-thing to work since 4 weeks now and my boss wants to see something in the near future :)
So thank you!
Greets
Leech
hhh January 30, 2012 07:13
hydrodynamics analysis(under water)
Dear friends,
i am doing analysis in under water hydrodynamics,i design one simple model in catia like 3D rectangular box,with flap,i dont how to start i want to know how to import that 3D model in open foam and how to mesh ,how to set boundary condition that is medium is water not air,what kind of solver i can choose for example in commericial software we do as to put outer domain inside cad model and set boundary conditions, meshing and to write udf for that flap,and compute in fluent and get results,these all work how do in openfoam,please kindly guide me as soon as possible for your valuable time spending in this area
Ed R August 20, 2013 08:47
Dear All,
Have you had any luck getting the floatingObject tutorial to run in parallel? I have try the methods posted above and it runs but the box just sinks and the simulation crashes. Any tips on how to get this to run in parallel would be much appreciated.
Thanks,
Ed
wyldckat August 21, 2013 06:28
Greetings Ed,
AFAIK, with this case, consider yourself lucky if it doesn't crash in serial!
The following bug report as not yet been fixed: http://www.openfoam.org/mantisbt/view.php?id=417
Nonetheless, you can try the schemes mentioned on these posts:
Best regards,
Bruno
haze_1986 March 7, 2014 05:10
Thanks Bruno for the information. I have encountered an error while the solver is solving for the cellDisplacement, did I do anything wrong?
| \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox          |
|  \\    /  O peration    | Version:  2.1.0                                |
|  \\  /    A nd          | Web:      www.OpenFOAM.org                      |
|    \\/    M anipulation  |                                                |
Build  : 2.1.0-0bc225064152
Exec  : interDyMFoam -parallel
Date  : Mar 07 2014
Time  : 16:49:54
Host  : "jhc"
PID    : 5675
Case  : /home/caelinux/OpenFOAM/caelinux-2.1.0/run/tutorials/multiphase/interDyMFoam/ras/groovyFloatingObject
nProcs : 2
Slaves :
1
"jhc.5676"
Pstream initialized with:
    floatTransfer    : 0
    nProcsSimpleSum  : 0
    commsType        : nonBlocking
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting motion diffusion: inverseDistance
Reading field p_rgh
Reading field alpha1
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu            0.09;
    C1              1.44;
    C2              1.92;
    sigmaEps        1.3;
Reading g
Calculating field g.h
PIMPLE: Operating solver in PISO mode
time step continuity errors : sum local = 0, global = 0, cumulative = 0
GAMGPCG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Courant Number mean: 0 max: 0
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.01
Time = 0.01
Centre of mass: (0.5 0.5 0.5)
Linear velocity: (6.34413156929e-18 0 -0.389586632117)
Angular velocity: (5.51568309119e-16 -1.30131089673e-15 4.81867632216e-18)
GAMG:  Solving for cellDisplacementy, Initial residual = 0, Final residual = 0, No Iterations 0
GAMG:  Solving for cellDisplacementz, Initial residual = 0, Final residual = 0, No Iterations 0
--> FOAM Warning :
    From function twoDPointCorrector::twoDPointCorrector(const polyMesh& mesh, const vector& n)
    in file twoDPointCorrector/twoDPointCorrector.C at line 164
    The number of points in the mesh is not equal to twice the number of edges normal to the plane - this may be OK only for wedge geometries.
    Please check the geometry or adjust the orthogonality tolerance.
Number of normal edges: 50186 number of points: 51492
[1] swak4Foam: Allocating new repository for sampledGlobalVariables
[0] swak4Foam: Allocating new repository for sampledGlobalVariables
Execution time for mesh.update() = 0.27 s
MULES: Solving for alpha1
Liquid phase volume fraction = 0.530701754355  Min(alpha1) = 0  Max(alpha1) = 1
GAMG:  Solving for p_rgh, Initial residual = 1, Final residual = 0.0042458526214, No Iterations 3
time step continuity errors : sum local = 0.000812490771455, global = -0.000136684627106, cumulative = -0.000136684627106
GAMGPCG:  Solving for p_rgh, Initial residual = 0.000101213989295, Final residual = 1.36407553462e-09, No Iterations 5
time step continuity errors : sum local = 3.43954420172e-08, global = 9.87711501195e-10, cumulative = -0.000136683639395
smoothSolver:  Solving for epsilon, Initial residual = 0.0326420728704, Final residual = 9.53691786432e-07, No Iterations 8
smoothSolver:  Solving for k, Initial residual = 1, Final residual = 7.52383903742e-07, No Iterations 14
ExecutionTime = 1.57 s  ClockTime = 2 s
Courant Number mean: 0.00180830835435 max: 0.0339703528711
deltaT = 0.01
Time = 0.02
Centre of mass: (0.5 0.5 0.492208267358)
Linear velocity: (0.00068164173596 -0.00307568326139 -0.715293177715)
Angular velocity: (0.0169842938365 0.00445484220003 0.000256960734948)
GAMG:  Solving for cellDisplacementz, Initial residual = 1, Final residual = 9.70021948361e-06, No Iterations 6
[1] processorPolyPatch::calcGeometry : Writing my 1512 faces to OBJ file "/home/caelinux/OpenFOAM/caelinux-2.1.0/run/tutorials/multiphase/interDyMFoam/ras/groovyFloatingObject/processor1/procBoundary1to0_faces.obj"
[0] processorPolyPatch::calcGeometry : Writing my 1512 faces to OBJ file "/home/caelinux/OpenFOAM/caelinux-2.1.0/run/tutorials/multiphase/interDyMFoam/ras/groovyFloatingObject/processor0/procBoundary0to1_faces.obj"
[1] processorPolyPatch::calcGeometry : Dumping cell centre lines between corresponding face centres to OBJ file"/home/caelinux/OpenFOAM/caelinux-2.1.0/run/tutorials/multiphase/interDyMFoam/ras/groovyFloatingObject/processor1/procBoundary1to0_faceCentresConnections.obj"
[0] processorPolyPatch::calcGeometry : Dumping cell centre lines between corresponding face centres to OBJ file"/home/caelinux/OpenFOAM/caelinux-2.1.0/run/tutorials/multiphase/interDyMFoam/ras/groovyFloatingObject/processor0/procBoundary0to1_faceCentresConnections.obj"
[0] [1]
[1]
[1] --> FOAM FATAL ERROR:
[1] face 1470 area does not match neighbour by 0.470508912681% -- possible face ordering problem.
patch:procBoundary1to0 my area:0.000414788088652 neighbour area:0.000416744305665 matching tolerance:2.25892959731e-08
Mesh face:146827 vertices:4((0.325 0.35 0.49252126208) (0.35 0.35 0.49252126208) (0.35 0.35 0.50903350177) (0.325 0.35 0.509192069482))
If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file.
Rerun with processor debug flag set for more information.
[1]
[1]    From function processorPolyPatch::calcGeometry()
[1]    in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 239.
[1]
[1]
EDIT* when relaxing the tolerance to 0.05, it runs longer, several timesteps before the error.
wyldckat March 7, 2014 16:04
Greetings haze_1986,
Honestly, I suggest that you upgrade to the latest OpenFOAM version. The version 2.1.0 is very likely to have had issues with the floating object tutorial, when small changes were made to the tutorial. And I'm not familiar with a "groovyFloatingObject" tutorial, but if it came from swak4Foam, then it might not be fully up-to-date either.
Best regards,
Bruno
haze_1986 March 7, 2014 21:53
Best regards,
Bruno
Greetings Bruno,
Would you recommend to use 3.0extend or 2.3.0? Thanks.
wyldckat March 8, 2014 16:44
Hi haze_1986,
Honestly, I suggest you install both. I'm not sure about the status of the floating object in either versions, but having both can come in handy, sooner or later.
Best regards,
Bruno
wuwenbo May 9, 2014 06:08
3d FSI dynamicfvmesh
Date  : Mar 07 2014
Time  : 16:49:54
Host  : "jhc"
PID    : 5675
nProcs : 2
Slaves :
1
"jhc.5676"
    floatTransfer    : 0
    nProcsSimpleSum  : 0
Create time
Reading field p_rgh
Reading field U
kEpsilonCoeffs
    Cmu            0.09;
    C1              1.44;
    C2              1.92;
    sigmaEps        1.3;
Reading g
Starting time loop
deltaT = 0.01
Time = 0.01
--> FOAM Warning :
deltaT = 0.01
Time = 0.02
[0] [1]
[1]
[1]
[1]
[1]
Hi,haze! I'm using foam-ext-3.0 to simulate 3d FSI problem. when i run in parallel,I encounter the same problem as you mentioned: "face area doesn't match neighbour ...." . It can work fine in serial and in 2d problem.
Have you fixed this problem? If you have, can you tell me how did you achieve that?
I hope my poor English will not hinder you understanding my meaning.
Best wish!
wuwenbo May 16, 2014 02:23
[0] --> FOAM FATAL ERROR : face 0 area does  not match neighbour by 0.00287477 with tolerance 0.0001.  Possible face  ordering problem.
 patch: procBoundary0to1 mesh face: 58328
[0]
[0]    From function
[0] processorPolyPatch::calcGeometry()
[0]    in file meshes/polyMesh/polyPatches/derivedPolyPatches/processorPolyPatch/processorPolyPatch.C at line 217.
[0]
[0]
[1]
[1]
[1] --> FOAM FATAL ERROR : face 0 area does not match neighbour by  0.00287477 with tolerance 0.0001.  Possible face ordering problem.
 patch: procBoundary1to0 mesh face: 58360
[1]
[1]    From function
[1] processorPolyPatch::calcGeometry()
[1]    in file meshes/polyMesh/polyPatches/derivedPolyPatches/processorPolyPatch/processorPolyPatch.C at line 217.
[1]
I use foam-3.0-extend to simulate FSI, and I still encounter this error, can you help me?
wyldckat June 22, 2014 13:22
Greetings wuwenbo and welcome to the forum!
Unfortunately you're not providing enough information in order to help you. Please read the following thread to understand what I mean: http://www.cfd-online.com/Forums/ope...-get-help.html
Because only in the second post you've made is there some inform about the exact error message. And that message seems to be due to the following reasons:
  1. You're running in parallel, which can increase the complexity of the problem. Possible solution: First try to run in serial mode, to see if you get the same error.
  2. The error message depends on what you're case is and what it looks like. More specifically, the error message suggests that the mesh is composed by very big cells and/or faces, for which the tolerance might not be applicable. For example, the message:
    is telling you that the tolerance is 0.0001, which is the maximum allowed error. But the error you're getting is 0.00287477.
Therefore, as I've indicated above, please read this thread: http://www.cfd-online.com/Forums/ope...-get-help.html - and then follow the steps given there to provide enough information for people on the forum to be able to help you.
Best regards,
Bruno
haze_1986 February 18, 2015 01:08
Originally Posted by wyldckat (Post 478972)
Hi haze_1986,
Best regards,
Bruno
Just a quick update for anyone exploring the tutorials with some recent findings between 2.3.x and extend3.1 versions. The floatingObject tutorial in 2.3 would be a better place to start. The tutorial in extend3.1 will have the object sinking, perhaps tuning the object properties will help but I would prefer 2.3's example which is really neat where the user can easily input the restrains and constrains.
foam extend 3.1 log at some time step:
Time = 3.71818
Centre of mass: (0.5 0.5 -67.128640124)
ashim March 10, 2015 15:08
Hi ,
I am facing the similar type of problem. I am trying to simulate a ship motion in OF2.3.x using waveDyMFoam (modified interDyMFoam). I have used displacementLaplacian solver for mesh motion (as in OF2.2.2) so that I can add more object. This solvers works fine for 2D and 3D box using wave at inlet. But when I am trying to use ship model, it is just sinking from first iteration and crash at the end. I am struggling with this problem for 2 weeks, still no success. I hope I will get some help from OF expert.
Ali
chun March 12, 2015 08:07
I just look this post and try the tutorial case.
I found out that there's decomposeParDict file in the system. (except I decide to parallel it into 4 part) That works just fine in my OpenFOAM 2.3.0
gautami August 13, 2015 14:17
Dear All,
I need help with post processing of floatingObject tutorial.
Kindly can you please let me know, how to obtain the displacement of floatingObject in the x-direction (translation of the box in x-direction) with respect to time?
Thank you.
Gautami.
