wall pressure, sloshingTank2D in InterDyMFoam
Dear all:
I ran sloshingTank2D with only one displacement value (read from a 6DoF.dat file). I set up the problem so that the wall pressure and phase (alpha values) are output to a fille. I set the time interval to 0.001. Now when I run InterDyMFoam for that one displacement value only, open foam outputs pressure and phase values for each time increment. How do I know which one is correct? Do I take the last file output as the final and correct output? Thanks! |
