January 30, 2012, 09:07 |
flow controled by outlet temperature
Let's have a water boiler - closed tank full of water. The hot water is outleted from the top, cold water is inleted in the bottom. Inlet water temperature is to be fixed. Outlet temperature changes accordingly to heat ballance and transfer in the system. To keep the ammount of consumed heat, I need to change the inlet=-outlet mass flux (or velocity) on deltaT of the system. With other words: to control mass flux by outlet water temperature. How to realize this ? Give me a direction, please. Is it a case for groovyBC ? It should be the start of some design test case. The idea is to solve it in transient. Is the buoyantBoussinesqPimpleFoam suitable solver for that simple case? Thanks a lot Last edited by soonic; January 31, 2012 at 15:39. |
b.c., control, tank |
Mass flow inlet and pressure outlet issue | nikhil | FLUENT | 5 | December 11, 2013 12:30 |
CFDesign V11 -- Reverse flow at outlet | maruthiv | Autodesk Simulation CFD | 1 | June 17, 2011 09:38 |
Pressure outlet in two-phase flow in horizontal 2D channel | AlmostSurelyRob | Main CFD Forum | 0 | November 17, 2010 07:32 |
Inlet and outlet flow rate | Neser | CFX | 1 | March 2, 2004 16:02 |
Question on checking incell temperature at outlet | Guoqing | Phoenics | 1 | June 4, 2003 17:50 |
