February 9, 2012, 05:35 |
Cyclic BC on side walls
Tom Witten
Rep Power: 14 |
Hi All,
I'm presently attempting to simulate flow over an object in a parallel plate channel in 3D by using a cyclic boundary conditions. To make this a little more understood, the geometry is as such: an inlet, an outlet, top/bottom walls, and for the sides instead of specifying symmetry or a wall, I put cyclic. The problem is when I try to run a case in pisoFoam I get floating point errors. If anyone has experience with this or can point me to a thread where this has been discussed (I couldn't really find an answer in the other threads) that would really help. Tom |
February 9, 2012, 07:34 |
Niels Nielsen
Rep Power: 27 |
Hi
It would help if you wrote how you create the cyclic boundary and post the output from the solver and attach as a log file. Also is it rotational cyclic or translate cyclic?
Linnemann PS. I do not do personal support, so please post in the forums. |
February 9, 2012, 08:38 |
Tom Witten
Rep Power: 14 |
Thanks for replying to my thread. Your request for the method of creating my mesh caused me to examine this issue more carefully. I used createPatch to create translational periodicity and it turns out I had incorrectly understood the behavior of the separation vector. I specified the separation vector correctly and am getting now good results. Anyway sorry for posting something that turned out so trivial. Regards, Tom |
cyclic side wall |
Display Modes | |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 17:08 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
Periodic boundary for side walls | jiju | CFX | 2 | February 3, 2008 17:24 |
[Commercial meshers] Converting meshes that includes interfaces | ham | OpenFOAM Meshing & Mesh Conversion | 29 | January 8, 2007 08:58 |
