Home > Forums > OpenFOAM Running, Solving & CFD
new les wall function
Old   February 6, 2012, 04:40
Default new les wall function
Jimmy Okua
gimba86 is on a distinguished road
Hi OFoamers
, I'm new in openfoam cfd toolbox and I'm using OF 2.0.1. I'm trying to implement a new LES wall function.
In particular, I'm interesting to make a wall fuction near at mutkRoughWallFunction in RAS turbolence.
I've already copied mutkRoughWallFunction directory, renamed it like muSgsRoughWallFunction and modified .C and .H files.
After that, I see that there are not make directory; so I copied the cartel LES from src to my user application folder and moved my muSgsRoughWallFunction
into wallfunction cartel.
I after added my new wall function in LES/make/files, and changed dinamic library name. By terminal, in the user application/LES I write:
<wclean
<wmake libso
, and I have a list of compiling errors.
In file included from derivedFvPatchFields/wallFunctions/muSgsWallFunctions/muSgsRoughWallFunction/muSgsRoughWallFunctionFvPatchScalarField.C:26:
derivedFvPatchFields/wallFunctions/muSgsWallFunctions/muSgsRoughWallFunction/muSgsRoughWallFunctionFvPatchScalarField.H:49:48: error: mutkWallFunctionFvPatchScalarField.H: No such file or directory
derivedFvPatchFields/wallFunctions/muSgsWallFunctions/muSgsRoughWallFunction/muSgsRoughWallFunctionFvPatchScalarField.H:67: error: expected class-name before ‘{’ token
derivedFvPatchFields/wallFunctions/muSgsWallFunctions/muSgsRoughWallFunction/muSgsRoughWallFunctionFvPatchScalarField.C: In member function ‘virtual Foam::tmp<Foam::Field<double> > Foam::compressible::LESModels::muSgsRoughWallFunct ionFvPatchScalarField::calcMut() const’:
derivedFvPatchFields/wallFunctions/muSgsWallFunctions/muSgsRoughWallFunction/muSgsRoughWallFunctionFvPatchScalarField.C:68: error: ‘patch’ was not declared in this scope
derivedFvPatchFields/wallFunctions/muSgsWallFunctions/muSgsRoughWallFunction/muSgsRoughWallFunctionFvPatchScalarField.C:70: error: ‘db’ was not declared in this scope
derivedFvPatchFields/wallFunctions/muSgsWallFunctions/muSgsRoughWallFunction/muSgsRoughWallFunctionFvPatchScalarField.C:70: error: expected primary-expression before ‘>’ token
derivedFvPatchFields/wallFunctions/muSgsWallFunctions/muSgsRoughWallFunction/muSgsRoughWallFunctionFvPatchScalarField.C:71: error: ‘const class Foam::compressible::LESModel’ has no member named ‘y’
derivedFvPatchFields/wallFunctions/muSgsWallFunctions/muSgsRoughWallFunction/muSgsRoughWallFunctionFvPatchScalarField.C:77: error: ‘Cmu_’ was not declared in this scope
can you help me?
gimba86 is offline   Reply With Quote
Thread Tools
Trackbacks are On
LES wall function ayoros OpenFOAM Running, Solving & CFD 10 June 15, 2016 03:30
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Wall function for velocity? johnblund OpenFOAM 0 March 10, 2011 09:50
Need some wall function approaches! yka8150 Main CFD Forum 0 September 21, 2009 23:08
LES wall treatment Valerio FLUENT 0 April 26, 2008 07:12
