Hydraulic Pipe Flow, which solver & BC:s?
Old   February 7, 2012, 04:16
Exclamation Hydraulic Pipe Flow, which solver & BC:s?
Johan Magnusson
magjohan is on a distinguished road
Hi!
Im trying to run a hydraulic pipe flow case. The case is basically very simple, more or less a pipe with a converget-divergent nozzle. Im assumed to know the inlet pressure and outlet pressure. Nothing else, i.e unknown velocities.
1. Initially, which solver should i use?
I've tried with simpleFoam
2. Which pressure BCs should i use?
My set-up now looks like this:
boundaryField
inlet
type fixedValue;
value uniform 12000000;
wall
type zeroGradient;
outlet
type fixedValue;
value uniform 2000000;
3. Which U BCs should i use?
Im now using a set-up like this
inlet
type pressureInletOutletVelocity; ;
value uniform (0 0 0);
wall
type fixedValue;
outlet
I've also tried zeroGradient without success!
Plz help me out, its so easy to setup using Ansys CFX, a verification in OF would be preferable!
BR
/magjohan
magjohan is offline   Reply With Quote
Old   February 7, 2012, 10:50
Default U zeroGradient inlet
AV.
Andrev is on a distinguished road
Did you try to set U as zeroGradient in the inlet BC ?
I mean :
inlet
type zeroGradient;
wall
type fixedValue;
outlet
Andrev is offline   Reply With Quote
Old   February 8, 2012, 09:52
Abhinay Kulkarni is on a distinguished road
Hi johan,
I am a new to openfoam and cfd in general.
I want to simulate a steady state, compressible flow of air through a bent pipe. Which solver can i use for this in Openfoam??
It would be great to get some help regarding my problem.
Thanking you in advance
Regards
Abhinay
Abhinay Kulkarni is offline   Reply With Quote
Old   February 8, 2012, 16:02
Johan Magnusson
Hi, I have tried with the mentioned boundary conditions, without any good results.
Andrev: I would make it simple and use the already implemented rhoSimplecFoam
Old   February 28, 2012, 06:58
yipiyaya8 is on a distinguished road
Hi Johan, do u have any improvement?
My case is i know inlet T, P and Velocity...also outlet T, P....
Hoever i want to let the openfoam to calculate the outlet Velocity ...I tried to use
oulet
but i dont know if setting value uniform (0 0 0); is correct or not?!
yipiyaya8 is offline   Reply With Quote
Periodic Pipe Flow LES dvolkind CFX 8 March 21, 2020 05:30
Solver for an incompressible, turbulent flow with heat transfer tH3f0rC3 OpenFOAM Running, Solving & CFD 9 June 17, 2019 06:12
Pipe flow with obstacle - HELP Min FLUENT 6 January 31, 2017 14:28
Blockage in pipe ( using solidwork flow simulation) jchow FloEFD, FloWorks & FloTHERM 1 January 16, 2012 16:03
pipe flow with noozle - ? on BC's mediode Main CFD Forum 2 March 14, 2011 10:31
