-   -   Cyclic BC on side walls (http://www.cfd-online.com/Forums/openfoam-solving/97119-cyclic-bc-side-walls.html)
thomas99 February 9, 2012 06:35
Hi All,
I'm presently attempting to simulate flow over an object in a parallel plate channel in 3D by using a cyclic boundary conditions. To make this a little more understood, the geometry is as such: an inlet, an outlet, top/bottom walls, and for the sides instead of specifying symmetry or a wall, I put cyclic. The problem is when I try to run a case in pisoFoam I get floating point errors. If anyone has experience with this or can point me to a thread where this has been discussed (I couldn't really find an answer in the other threads) that would really help.
Tom
linnemann February 9, 2012 08:34
Hi
It would help if you wrote how you create the cyclic boundary and post the output from the solver and attach as a log file.
Also is it rotational cyclic or translate cyclic?
thomas99 February 9, 2012 09:38
Thanks for replying to my thread. Your request for the method of creating my mesh caused me to examine this issue more carefully. I used createPatch to create translational periodicity and it turns out I had incorrectly understood the behavior of the separation vector. I specified the separation vector correctly and am getting now good results. Anyway sorry for posting something that turned out so trivial.
Regards,
Tom
