error message after running icoFoam
Old   February 9, 2012, 16:35
Question error message after running icoFoam
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
Dear Foamers,
while running case on OpenFOAM by icoFoam solver I've gotten this message but i could not understand exatcly where problem is? please help
Courant Number mean: 0.395781 max: 2.36188e+294
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 void Foam::fvc::surfaceIntegrate<Foam::Vector<double> >(Foam::Field<Foam::Vector<double> >&, Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
#4 Foam::tmp<Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
#5 Foam::tmp<Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
#6 Foam::fv::gaussLaplacianScheme<Foam::Vector<double >, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/icoFoam"
#11 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#12
Floating point exception
Ahmed Khattab is offline   Reply With Quote
Old   February 10, 2012, 02:48
Bernhard Grieser
BernhardGrieser is on a distinguished road
Originally Posted by rebel ahmed View Post
Dear Foamers,
Courant Number too high. Physical velocity exceeds "numerical" velocity. Smaller time step required.
BernhardGrieser is offline   Reply With Quote
Old   February 10, 2012, 13:38
Default too high courant number
ahmed
i tried to adjust time step and cell size. but not working.
also i see that mean courant is about 0.3.
Old   February 10, 2012, 14:45
cfd-noob is on a distinguished road
Last time I saw that it was a because of a singularity.
Your mean value is pretty low compared to the maximum. You can try to watch the result with paraView and maybe make a bigger radius at the point of the Maximum if this is possible.
cfd-noob is offline   Reply With Quote
Old   February 10, 2012, 15:27
Francesco Capuano
francesco_capuano is on a distinguished road
The floating point exception error occurs when the solution contains NaNs (Not a Number). To prevent meaningless solutions, OpenFOAM is provided with a floating point exception trapping represented by the environment variable $FOAM_SIGFPE: when active, the solution stops as soon as a NaN appears in the field. If you wish to let the solver continue running, you can unset FOAM_SIGFPE by commenting its definition within the /etc/bashrc file (you will need to restart your shell).
However, it is evident that your singularity is caused by the high Courant number, therefore I would suggest that you first check your boundary and initial conditions and reduce (as already suggested) your time-step. Starting from a very small time-step (e.g. 1e-10s) sometimes works, at least in my experience
Cheers,
Francesco
francesco_capuano is offline   Reply With Quote
Valgrind claims invalid free when running icoFoam from OpenFOAM 1.6-ext andrewryan OpenFOAM Bugs 3 March 30, 2011 08:00
Suse10 FoamX problem frank178 OpenFOAM Installation 6 January 14, 2010 04:18
problem when running icoFoam on a complex shape flow field wendywu OpenFOAM 1 May 20, 2009 23:40
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
