decomposePar failed in "field transfer"
Dear all,
I am trying to run a case in parallel, when run "decomposePar", it worked fine before "field transfer". no error, on warning, but just stopped..as follows: Processor 15 Number of cells = 30270 Number of faces shared with processor 12 = 420 Number of faces shared with processor 14 = 1096 Number of faces shared with processor 8 = 343 Number of faces shared with processor 10 = 551 Number of processor patches = 4 Number of processor faces = 2410 Number of boundary faces = 8475 Number of processor faces = 10809 Max number of processor patches = 7 Max number of faces between processors = 2410 Processor 0: field transfer Initializing the GGI interpolator between master/shadow patches: iminy/imaxy Initializing the GGI interpolator between master/shadow patches: ominy/omaxy it just stopped here, without finishing the decomposePar. The result is, in processor0/1/2/3/4/5... there is only the file "constant", but no file "0".. Does anyone may help on this? what may be the problem? Thank you so much!! Aqua |
That means you don't have the initial conditions folder named "0". If you are using different time for initial condition, try changing the start time in controlDict. |
Hello, Abhishek,
Thank you so much for your reply. Turned out that the mesh is not right. So current I am trying to modify the mesh... Cheers! Aqua |
