Home > Forums > OpenFOAM Running, Solving & CFD
Too high temperature in the spray?
Old   February 16, 2012, 06:31
Unhappy Too high temperature in the spray?
Chen Huang
chenhu is on a distinguished road
Hello everyone,
I am working on a solver (version 1.6.x) which combines the dieselFoam (spray) and engineFoam (premixed turbulent combustion). Since the fuel temperature is 320 K and ambient air temperature is 370 K, the region where there is fuel vapor should have lower temperature (due to evaporation, heat transfer), but I got higher temperature (e.g. 500 K) in that region.
Could anyone know the reason for this problem?
Thanks!
chenhu is offline   Reply With Quote
Old   February 16, 2012, 11:00
Smile
Chen Huang
Problem solved :-)
The reason for the high temperature in the spray (fuel vapor zone) is due to the incorrect calculation of heatTransferSource. I am using the total enthalpy equatioin, but the heatTransferSource is calculated using sensible enthalpy (in version 1.6.x). This gives smaller sink term in the hEqn.H, and it gives higher temperature.
So be careful if you are updating your solvers or libs from old versions to 1.6.x (although it is quite old too) when dealing with H and Hs!
Chen
Thread Tools
Trackbacks are On
Temperature loss in compressible solvers in high speed flows vkrastev OpenFOAM Running, Solving & CFD 0 May 14, 2011 04:41
High Combustion Temperature in the EBU model Mehdi CD-adapco 0 April 24, 2006 05:53
high temperature object in water mike Main CFD Forum 5 September 1, 2004 12:11
Why temperature is so high? Albert FLUENT 2 June 22, 2003 11:28
temperature too high in eddy dissipation Peter Lemtis FLUENT 3 November 24, 2002 01:45
