Pipe flow in settlingFoam floating point exception |
December 21, 2011, 11:18 |
#1 | ||||||
Jochem van den Bosch
Rep Power: 14 |
Dear fellow FOAM'ers,
I'm trying to simulate a two phase (sand/water) flow in a straight pipe using settlingFoam. To start, I altered the tank3D tutorial of settlingFoam. I use a pipe mesh which I already have succesfully used with single phase flows. Unfortunately, whatever I try, I'm getting a 'Floating point exception' after 5-20 iterations. I suppose this has something to do with the boundary conditions but I cannot find my mistake. These are them. Would anybody know where I went wrong??? Quote:
December 21, 2011, 16:03 |
Stephen Lucchesi
Rep Power: 14 |
your courant number is going crazy. Likely the timestep is set too big. try reducing it.
December 22, 2011, 04:12 |
#3 | |
Rep Power: 14 |
Hi Stephen, my courant number is going like crazy indeed, but when I reduce my timestep with a factor 1000! to 0.0001 I get the same message after 54 iterations.
But when I look at those 54 iterations in ParaView I see no pressure distribution (see attachment) and also no speeds... This makes me believe there is something wrong in the boundary conditions.... Quote:
February 16, 2012, 03:05 |
Matt
Hi Jochem, I am having a similar issue to this, did you manage to fix it?
February 16, 2012, 03:24 |
Rep Power: 14 |
Hi Matt, my problem was that I set the speed in a direction perpendicular to the wall instead of parallel. But in general the problem can be solved by decreasing your time step. What solver are you using?
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
simpleFoam Floating point exception error -help | sudhasran | OpenFOAM Running, Solving & CFD | 3 | March 12, 2012 16:23 |
rhoPimpleFoam aborting with floating point exception (because of wrong bc p?) | space | OpenFOAM Running, Solving & CFD | 2 | October 5, 2011 05:44 |
floating point exception in turbulent model | marco | Siemens | 0 | December 19, 2008 11:02 |
Floating point exception during the initialisation | Julie Polyakh | FLUENT | 1 | January 6, 2004 23:07 |
