rho in buoyantSimpleFoam
Old   May 17, 2012, 04:01
Default rho in buoyantSimpleFoam
Arina
Akuji is on a distinguished road
Send a message via ICQ to Akuji
Hello!
I try to understand how the solver buoyantSimpleFoam works. I use hotRoom for basis. I create my own geometry with heater and use the same BC.
the 1st problem, that residualas are too much (I want to have a residuals ~e-04)
The 2nd question is about rho: while iterationg I see in terminal-window:
DILUPBiCG:  Solving for Ux, Initial residual = 0.0141216, Final residual = 0.000127767, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.0152304, Final residual = 0.000140921, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.0127635, Final residual = 0.000111577, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 0.000611936, Final residual = 6.79723e-06, No Iterations 1
DICPCG:  Solving for p_rgh, Initial residual = 0.00395034, Final residual = 3.77746e-05, No Iterations 33
time step continuity errors : sum local = 2.08489e-06, global = 1.39649e-19, cumulative = 3.59289e-18
rho max/min : 1.18706 1.0768
DILUPBiCG:  Solving for epsilon, Initial residual = 0.00028293, Final residual = 2.49851e-05, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 0.000662009, Final residual = 5.58047e-05, No Iterations 1
The tabulated values for my boundary conditions for air are:
min 1.093
max 1.205
Results for rho calculated by openFOAM very close to tabulated values, but not the same.
Does anybody know how OF calculates rho?
Akuji is offline   Reply With Quote
Old   May 21, 2012, 06:51
Arina
nobody knows?
Old   May 22, 2012, 06:08
Arina
Originally Posted by daffodil1003 View Post
Thank you so much for the post.
But...what about answer?
rhoPimpleFoam floating point error dancfd OpenFOAM Running, Solving & CFD 6 January 5, 2014 20:57
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 13:38
rho euation in rhoPisoFoam nileshjrane OpenFOAM Running, Solving & CFD 4 October 5, 2010 07:44
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
Error log vw.cfd OpenFOAM 6 August 7, 2009 05:44
