-   -   a little confused with the implementation of compressibleInterFoam (http://www.cfd-online.com/Forums/openfoam-solving/98282-little-confused-implementation-compressibleinterfoam.html)
su_junwei March 7, 2012 08:28
Hi Foamers
The following thread discussed the implementation of compressibleInterFoam.
http://www.cfd-online.com/Forums/ope...interfoam.html
I am confused with the implementation of dgdt in the file pEqn.H
In this thread, we can get.
dgdt = { ( psi2 / rho2) - (psi1 / rho1) } DpDt
However, in the implementation, it gives
dgdt = (pos(alpha2)*psi2/rho2 - pos(alpha1)*(psi1/rho1))*(p_rghEqnComp & p_rgh);
Is this right? shoud it be
dgdt = (psi2/rho2 - psi1/rho1))*(p_rghEqnComp & p_rgh);
where are alpha1 and alpha2 from?
would you please give me some tips?
Best Regards, Junwei
su_junwei March 8, 2012 03:03
I got it. pos is just a sign function.
krishtej23 May 7, 2014 17:33
Error while executing compressibleinterfoam
I am trying to run a simulation using compressibleinterfoam application. I changed the alpha1 to alphaair, alphawater and alphadrop by creating each file separately. But when I try to run the code I get an error telling:
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.1-221db2718bbb
Exec : compressibleInterFoam
Date : May 07 2014
Time : 17:32:26
Host : "mountaineer"
PID : 15228
Case : /auto/scratch/mdinc/ottawa_simulations/new_corrected_B_cases/3D_simulations/earth_3b_of
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading g
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field alpha1
--> FOAM FATAL IO ERROR:
cannot find file
file: /auto/scratch/mdinc/ottawa_simulations/new_corrected_B_cases/3D_simulations/earth_3b_of/0/alpha1 at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
It is appreciable if you can help me in solving this.
Thank you.
