swakExpressions
Hi All,
First of all thanks to Bernhard Gschaider for swak4Foam (http://openfoamwiki.net/index.php/Contrib/swak4Foam), I am getting into some of the swakExpression stuff to calculate volumetric flow rate across planes. I have been using something like the example: Code:
planeAverage to grab volumetric flow rate and then I will eventually use it for cup-mixing (or mixing-cup?) average (mass flow averaged of a variable) of a system. My question is...is the plane in question a cutting plane or the plane of faced of the cells parallel to the plane I am providing? I ask because I noticed a slight difference between the flowthrough that is stated above and patchMassFlow if I use a simpleFunctionObject on the outlet patch. It could be my mistake on the differences...since I just started messing with this today. Thoughts? Thanks for your help. |
Therefor sampledSurfaces are computationally expensive and shouldn't be used excessively Quote:
If you want a control surface that is aligned with the mesh faces then a faceSet is a better choice (here the mass-flow should be exactly the one going in and out of the simulation ... if the run is converged. For specifying the faceSet you can use the setSet-utility. Either with one of the OF topoSources or the expressionToFace-topoSource that comes with swak (that one picks faces for the faceSet by evaluating a logical expression and taking all faces where the condition is true on one side and false on the other) For different approaches to control-surfaces have a look at the angledDuct-example that comes with swak |
Thanks for the reply, I believe I just wanted a confirmation that I was thinking correctly and my hunch was correct....and that is what you provided. For others, I will just post the code that I finally come up with. Thanks again.
thanks for your help in advance. |
