Thermophysical models and properties
Old   March 8, 2012, 06:57
Default Thermophysical models and properties
Gitesh
Gitesh P is on a distinguished road
Hello everyone,
I want to know about Thermophysical models and properties used in OpenFOAM. So, can any one give me suggestion about liturature from where I can read the model equations and etc about it.
Regards,
Gitesh
Gitesh P is offline   Reply With Quote
Old   March 8, 2012, 09:42
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
you should find many things by searching through the files at:
OpenFOAM-2.1.0/src/thermophysicalModels/
other than that it depends on your physics.. is it biased toward chemistry?Lagrangian approaches?solid?liquid?heatTRanfer?compressible effects?
can't rly point a bible i guess, that's the beuty, if i may say, of CFD, you kinda gotta know a bit of everything, sometimes more than you thought you had
but you could check the physics books from Sears & Zemansky books
Best Regards
/calim
"Elune will grant us the strength"
calim_cfd is offline   Reply With Quote
Old   March 9, 2012, 03:01
Christian Lucas
Chris Lucas is on a distinguished road
if you need additonal thermo models, have a look at the OpenFOAM ext real gas branch.
http://openfoam-extend.git.sourcefor...dRealGasThermo
Best Regards,
Christian
Chris Lucas is offline   Reply With Quote
Old   March 9, 2012, 09:36
Gitesh
Thank you for your help !!
I am not much familiar with OF. I am going to work with real gas assumption. Lucas can you say me what is the meaning of 'realGasEThermo + realGas_pEqn 4 rhoPisoFoam'.
BR,
Gitesh
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Temperature-dependent material properties in chtMultiRegionFoam-Solver sebonator OpenFOAM 0 November 15, 2010 08:15
Viscosity properties for transport models ozzythewise OpenFOAM Running, Solving & CFD 4 October 7, 2010 20:39
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
